possible clutch tranny problem (clutch wont engage)
Old Sep 23, 2004 | 11:29 AM
5litereater's Avatar
Default possible clutch tranny problem (clutch wont disengage)
im frustrated.
PennDot (PA's oh-so-wonderful road workers) fucked my car up. i was coming to a stop (no more than 5-7mph) when i feel/hear an awful slam. something (whichi later found out was my tie rod bushing) rolled out from underneath my car and into a gigantic puddle (we got fucked from hurricane ivan this past weekend). so im furious i go park my car and i hope everythings cool. i later figure out it had jarred my tie rod bushing over the bolt. this isnt the worst part.
on my way home from work im having a hard time shifting (not a transmission problem it seems; but a clutch problem). so i get to a gas station park it and there it sat for a day or two until i had time to go back and **** around with it for a bit. i fix the tie bar situation, do visual check of the linkage, tranny, clucth cable, clutch pedal and everythign seems fine. start it up; iit doesnt go into gear. ****!
i get it towed, i rip off the tranny to find that the spring on my throwout bearing had snapped (i ghetto rigged the spring the last time cuz it broke so i was asking for it to break on me). i replace it with a new spring, check to make sure the clutch arm was moving the throwout bearing smoothly (it was), and put everything back together.
i get in my car, put my foot on the clutch; the pedal's dead. i proceed to tighten my clutch cable, but even after tightening it all the way down i still had a dead pedal. im confused/pissed off now because i have a new throwout bearing, clucth, PP, throwout bearing spring, and clutch cable but i have a dead pedal???
someone please give me some insight im stumped. i need my car by saturday for a race!
TIA
Old Sep 23, 2004 | 11:59 AM
Default Re: possible clutch tranny problem (5litereater)
bump for some insight!
Old Sep 23, 2004 | 09:34 PM
help pls
Old Sep 24, 2004 | 06:36 AM
bump
Old Sep 24, 2004 | 07:20 AM
crx_88_si's Avatar
is the cable still attached at both ends (trany and pedal ?)
Old Sep 24, 2004 | 08:21 AM
TheJunBuilt's Avatar
through out bearing...... thats what happen to my 91dx last summer
Old Sep 24, 2004 | 02:48 PM
Default Re: (91mugenDx)
but its new. is it possible that it went bad in less than 2000 miles?
Old Sep 24, 2004 | 03:38 PM
Default Re: (5litereater)
anyone else????
Old Sep 24, 2004 | 05:05 PM
Super Chicken's Avatar
It's possible that your clutch fork is bent or the pivot point has worn through. If you were just in there and didn't notice if either one of these was the case then your probably just fucked. Just guessin I'd say the pivot ball broke off or wore through the clutch fork, but I'm diagnosing something from 600 miles away on a keyboard.
Old Sep 25, 2004 | 12:09 PM
Default Re: (Super Chicken)
so just replacing the clutch fork could solve the problem? i have a ls tranny i could swap the fork off of that.
is it possible that something is internally damaged?
thanks for the help...anyone else?
Old Sep 25, 2004 | 02:14 PM
bump
Old Sep 26, 2004 | 07:47 AM
im gonna try and swap out the clutch fork. if anyone else has any suggestions let me know.
Old Sep 27, 2004 | 03:45 PM
ok so i took the clutch fork off, reattached the throwout bearing and spring, put the tranny back on and the clutch fork moves but doesnt do anything. the throwout bearing moves smoothly on the spline and seems like it should make contact with the pressure plate but doenst.
i dont understand how a new clutch setup with no more than 2k on it could be giving me so many problems.
im in desperate need of my car please help.
Old Sep 27, 2004 | 04:27 PM
bump...please help
Old Sep 27, 2004 | 04:59 PM
honda-tech is disappointing me. im used to fast replies and help but im not gettin ****. cmon somebody has to know something!
Old Sep 29, 2004 | 10:57 AM
i cracked the clutch disc and pressure plate off last night and everything seems absolutely fine. no loose/ broken springs on the disc and all the fingers are still strong on the pressure plate.
im not sure where to look for the problem now? my clutch fork moves smoothly (along with the throwout bearing assembly) but its almost like it isnt reaching the pressure plate?
i dunno any advice at this point would be more than helpful
TIA.
Old Sep 29, 2004 | 12:17 PM
therealciviczc's Avatar
You are sure that the cable is adjusted properly and is attached properly under the dash in the clutch pedal?
If so, check the spring, fork, bearing orientation. The bearing should be first, obviously, with the fork next, and the spring attached to the bearing behind the fork, not between the fork and bearing like people often do, which causes the spring to break.
If that is ok, then I'm thinking the cable somehow stretched or is not in the bracket correctly on the transmission. It sould be through the braket with the large nut, and the funny washer thing that holds it in the bracket on the top side of the bracket. There should be a bushing under the clutch arm, and the cable will need to be adjusted probably around 1/2 out. Remember that you will need to be pulling up a little on the clutch arm to get enough adjustment to get the travel required to engage and disengauge the clutch.
When the cable is unhooked, can you move the arm up and hear the throwout hitting the fingers? If so, that point of contact is going to be on the low side of adjustment.
I know this may not be helpful and is sort of remedial, but I really don't know what your level of knowledge on the topic is, so I don't mean to suggest things you already know. I'm just trying to help.
Old Sep 29, 2004 | 12:22 PM
Default Re: (therealciviczc)
ive gained quite a bit of knowledge over the past year or so. i have done all the normal adjustments (put throwout bearing assembly together in that order, adjusted clutch cable accordingly) but the problem is i dont feel the throwout bearing contacting the pressure plate. what could cause this?
BlueStar
Jan 15, 2009 01:50 PM
Coolcat55
Sep 19, 2007 03:06 PM
mawkiemarc
Aug 1, 2005 08:41 PM
tony88crx
Jun 21, 2005 06:37 PM
BoostedED9
Nov 13, 2002 05:47 AM
