H22 Secondary runner question
Old Sep 23, 2004 | 10:08 AM
1point7db2's Avatar
Default H22 Secondary runner question
On my motor there is no diaphragm or actuator for the secondary butterflies, but there is a spring on the butterflies and I can move them and they spring back. Are they opened or closed when they spring back?
Old Sep 23, 2004 | 10:10 AM
98TypeSH's Avatar
Default Re: H22 Secondary runner question (h22rexguy)
if they spring back forward then they are closed. Vaccume is what actually controls the secondaries (other than the ecu etc..). If you pull their vac hose they stay open.
Old Sep 23, 2004 | 10:14 AM
99_SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22rexguy &raquo;</TD></TR><TR><TD CLASS="quote">On my motor there is no diaphragm or actuator for the secondary butterflies</TD></TR></TABLE>
There is, its actually a black box mounted under the intake manifold. You just dont see it...
Old Sep 23, 2004 | 10:24 AM
red92si's Avatar
There is the aforementioned black box that controls them, as well as a vacuum diaphram on the side of the IM that pushed the secondaries open at around 5k rpm.
Old Sep 23, 2004 | 01:45 PM
1point7db2's Avatar
Default Re: (red92si)
I have no diaphragm. There is a plug hanging labeled IAB. Maybe the previous owner removed the butterflies in the IM.
CAN97SH
Suspension & Brakes
33
May 28, 2007 07:43 PM
nek9
Jun 13, 2006 11:08 AM
EM2Civic
May 25, 2004 09:09 PM
KENLUDE97
Mar 17, 2003 11:15 AM
