Losing Spark after engine gets hot.. anybody else?
Old Dec 11, 2001 | 11:32 AM
XR4racer's Avatar
Default Losing Spark after engine gets hot.. anybody else?
Ok, thanks to a couple other peaople, I may have an idea about what's causing it, but I'm still curious as to how many other people have had this problem. My 2001 ITR with only about 8400 miles on it just cuts off after the engine gets good and warmed up. Upon pulling a plug, I found I have no spark, until the engine cools down again. No codes are being thrown, and the distributer cap/rotor looks good.. Anybody else have this happen? Any ideas? Any help is appreciated.
Old Dec 11, 2001 | 11:35 AM
Big Phat R's Avatar
Default Re: Losing Spark after engine gets hot.. anybody else? (XR4racer)
My 2001 ITR with only about 8400 miles on it just cuts off after the engine gets good and warmed up......
Sounds like a warranty problem to me - bring it back to the dealer!
Old Dec 11, 2001 | 11:39 AM
Back in Black's Avatar
Rather OG
Default Re: Losing Spark after engine gets hot.. anybody else? (Big Phat R)
You've obviously not seen Robert's car...
Old Dec 11, 2001 | 11:54 AM
Cosworth's Avatar
Default Re: Losing Spark after engine gets hot.. anybody else? (Darth VadeR)
LOL... I can see this convo between Rob and the dealer.
Rob: I'm here for some warranty work... my sparks don't fire.
Dealer: We don't remember selling any totally gutted and completely modified race car.
Rob: But, it's an Acura... I only have 8000 miles.
Dealer: Get-outta-heeeere... that ain't no street car.
Old Dec 11, 2001 | 12:01 PM
XR4racer's Avatar
Default Re: Losing Spark after engine gets hot.. anybody else? (Cosworth)
Yep.. you got it man.. U can see my predicament. I've got a few ideas, thanks to Yack, Corey, Willard and Karl but I'm looking for any second opinions before I perform surgery.
Old Dec 11, 2001 | 12:03 PM
Splat's Avatar
Collector-o-Guns and Drinker
Bobby - You could always plead -- "But it's so DANGEROUS driving on the streets! I need the full cage!"
Pat, who would be glad to lend Bobby some Volvo spark (seem to have too much of my own)
Big Phat R's Avatar
O I C
check your distributor bearing then
Old Dec 11, 2001 | 12:09 PM
Honda318dx's Avatar
I still believe its your ignitor, did you make it home ok? See if you can swap yours with Wills and run it around is see it it cuts off, Takes only a couple mins to change.. You will see what i am talking about after you take the cap off..
Old Dec 11, 2001 | 12:14 PM
XR4racer's Avatar
Default Re: Losing Spark after engine gets hot.. anybody else? (Honda318dx)
Thanks man.. It's halfway home. I had it towed to my Dad's house in Greensboro and borrowed his truck to get back to Charlotte. Gonna rent a trailer and pick it up in a day or two, and begin the troubleshooting process. Thanks again for the help.
Old Dec 11, 2001 | 12:23 PM
Mike M's Avatar
Founding Member
Rob I agree Sounds like the ignitor I had this problem in my car with the old engine we switched out the ignitor and it was fine, although the dealer wouldnt believe that it was the ignitor, So finally I made them switch it out and try it and low and behold I was right, and covered under warranty. The ignitor costs about $135, Even the way your car is They should cover it Its not like you have an aftermarket ignition, They would have to prove that whatever you have aftermarket in the car caused the ignitor to fail. I really cant see them saying "Well We believe the Cage caused the ignitor to malfunction" Good luck If they give you crap, I have a # you can call and It Will be taken care of.
Old Dec 11, 2001 | 12:27 PM
XR4racer's Avatar
Default Re: Losing Spark after engine gets hot.. anybody else? (TypeRmsm)
Thanks Mike.. I may give it a try.
Old Dec 11, 2001 | 12:47 PM
Tomakit's Avatar
Same thing happened to me.
Ignitor, from what i gather.
Tom
Old Dec 11, 2001 | 12:48 PM
chad's Avatar
Moderator
mike he has a VAFC.....tap into ecu lines....wait do you have a VAFC robert?
Old Dec 11, 2001 | 12:58 PM
Rather OG
Default Re: Losing Spark after engine gets hot.. anybody else? (chad)
yes, he does
Old Dec 11, 2001 | 01:00 PM
Mike M's Avatar
Founding Member
But the VAFC doesnt tap into any part of the ignition system, They cant refuse to warranty a part without proving that it was caused by an aftermarket piece. I'm sure they will take care of it, If not I'll give you a # to call.
Old Dec 11, 2001 | 01:41 PM
XR4racer's Avatar
Yes, I do have a V-AFC, but I still agree with Mike.. but I wonder if the dealer would have the same viewpoint.
austinkli
23
Feb 7, 2008 12:57 PM
Bulli Kid
28
Jul 19, 2006 10:17 AM
superpirate25
Nov 27, 2003 11:49 AM
krookedeg6
Apr 4, 2003 01:19 PM
XR4racer
Dec 11, 2001 01:56 PM
