s2 stg2 cams untune?
Old Sep 22, 2004 | 08:41 PM
JFG Kevin's Avatar
Default s2 stg2 cams untune?
i'm planning to roll untune for more then a year, but i will be using a chipped s2 ecu, is it a good idea or should i not do it and save up.
Old Sep 22, 2004 | 09:51 PM
B00ST2nR's Avatar
Default Re: s2 stg2 cams untune? (aznstyler119)
Tune them!!! Definately get some Cam Gears if you haven't already, and get some type of Fuel Tuning device like Hondata or VAFC and go Tune it on a Dyno. It'll make your car run SOOO much better and stronger. Not only will your car run reliable, it'll give you the most potential power gain with the cams after you tune.
Old Sep 22, 2004 | 10:13 PM
JFG Kevin's Avatar
Default Re: s2 stg2 cams untune? (B00ST2nR)
problem is i got money to put them on just not tune them after they are on.
Old Sep 22, 2004 | 10:18 PM
B00ST2nR's Avatar
I'm sure you can come up with $150 bucks for an hour of Dyno tuning. Those cams might even make your car run worse if they're untuned. I had Skunk2 Stage 1 cams in my car, and it ran like **** before I tuned them.
After it was tuned, it ran like a whole new different car.
Old Sep 22, 2004 | 10:24 PM
Sack Master's Avatar
Tune it yourself. A little track time on grudge night and knowing what you are doing goes a long way.
Old Sep 23, 2004 | 09:09 AM
gt35r's Avatar
Default Re: s2 stg2 cams untune? (Sack Master)
I can burn you a chip. just tell me the mods you got. If you dont tune then you will have serious problems. I just put stage 2's in my car and it died a whole bunch a times before i tuned it
nengx07
May 27, 2009 05:12 PM
johnny_bighood
11
Apr 29, 2009 10:14 AM
tnsxsear1
Feb 2, 2005 11:08 AM
acatak
Jul 13, 2002 02:19 PM
Jaisun
Jun 18, 2001 01:04 PM
