ARP head studs with out washers
Old Sep 22, 2004 | 08:24 PM
eg6cusco10pt's Avatar
Default ARP head studs with out washers
where can i find some similar washers for the nuts and ARP head studs also was wondering if i can use lock washers that was the closest that i found thanks for looking.
Old Sep 22, 2004 | 08:37 PM
iv's Avatar
iv
Order replacements from ARP don't skimp on the important stuff
Old Sep 22, 2004 | 08:45 PM
S9i1R's Avatar
Default Re: ARP head studs with out washers (eg6cusco10pt)
I just bought some hardened washers, the only difference is the thickness.
Old Sep 22, 2004 | 09:04 PM
Default Re: ARP head studs with out washers (S9i1R)
what about lock washers yes or no???
Old Sep 22, 2004 | 09:44 PM
HoOridin's Avatar
if remember..i dont think if it's just a regular flat kind of washer...
Old Sep 22, 2004 | 10:39 PM
Eddiebx's Avatar
if ur needing a lock washer to keep the bolts form loosening, then you got bigger problems, in essence, just get some replacement washers from ARP and call it a day,
Old Sep 23, 2004 | 01:16 AM
@ries's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6cusco10pt &raquo;</TD></TR><TR><TD CLASS="quote">what about lock washers yes or no???</TD></TR></TABLE>I say no and like previously stated order replacement ones from ARP
Old Sep 23, 2004 | 01:53 AM
RedZone's Avatar
Default Re: ARP head studs with out washers (@ries)
you can get them from summitracing.com
I beleave these are the ones you need, messure to be sure
http://store.summitracing.com/...0&y=0
Old Sep 23, 2004 | 05:35 AM
CHEETAH's Avatar
no it will throw off the torque spec ... use flat steel washers ... if you're in a bind, chop a couple stock headbolts or main cap bolts in half and use those washers, use a drill and vise and open up the hole to fit the arp studs.
the washers are pretty important in clamping.
greg
Old Sep 23, 2004 | 05:39 AM
b19coupe's Avatar
Order the replacement washers from ARP, and while you are at it, get some moly lube.
WAFFLES's Avatar
Default Re: ARP head studs with out washers (CHEETAH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH &raquo;</TD></TR><TR><TD CLASS="quote">
greg</TD></TR></TABLE>
now that's ingenuity.
NegativeXero
Nov 8, 2007 10:16 PM
kornerk12
Feb 7, 2007 09:03 PM
d16dcoe45
Oct 27, 2006 03:19 PM
Fatty_1775
Feb 9, 2006 11:02 AM
vtec.dc2
Aug 20, 2003 09:21 AM
