04 civic stock head unit.. what can i do?
Old Sep 22, 2004 | 08:04 PM
blueinfinity's Avatar
Default 04 civic stock head unit.. what can i do?
well the plan is to wire my car with everything i want then get my head unit LAST so i get one that suits my needs and im not paying for **** i dont need
I want to run an amp with 1 possibly two 12's in the trunk in a false floor. hooking these togethor i think i can figure out. but is there a way i can run them off the stock deck (dont need to sound the best) untill i get a new deck with rca out etc..
also what size are the door speakers 5 1/4 iv eheard can someone confirm and do i want an amp for the front also?
Old Sep 23, 2004 | 06:10 AM
B18C_EJ8's Avatar
Get a line out converter, splice into your factory speaker wires and run RCA's from the converter to your amp.
And yes, the speakers up front are 5 1/4".
Old Sep 23, 2004 | 11:30 AM
Default Re: (B18C_EJ8)
a line out converter? k so i'd spice into my rear left and right.. would that killt he use of them two or should it work ok?
thanks!!
Old Sep 23, 2004 | 04:13 PM
B18C_EJ8's Avatar
All you're doing is splicing in, so the speakers will still work...
Old Sep 28, 2004 | 03:52 PM
ANDREW D's Avatar
Default Re: 04 civic stock head unit.. what can i do? (blueinfinity)
I would really suggest you replace the factory head unit first. Its the most important thing. The signal strenth going to you amp from your factory head unit will be really weak. You get an aftermarket headunit with 4 or more volt pre-outs it will make your subs sould ALOT cleaner and hit harder. Your front and rear speakers will also sound alot better and play louder with an aftermarket headunit.
Wait for the subs, get a headunit first
Old Sep 29, 2004 | 01:55 PM
liv2wrshp's Avatar
Default Re: 04 civic stock head unit.. what can i do? (ANDREW D)
Yeah, definitely get a new head unit. Just get a low end panasonic or kenwood. You rca voltage is going to suck if you use a converter. Trust me.
Jimi Hondrix
Audio / Security / Video
12
Sep 16, 2015 05:31 AM
jmaz
30
Mar 25, 2007 09:30 AM
bigmurr
Jul 26, 2005 09:39 AM
JMD
Apr 11, 2005 06:22 PM
dacaveman
Sep 7, 2003 02:16 PM
