Taillights, instrument lights all went out, checked fuse plz help
Ok, i started my car, turned my lights on, and then my guage lights went out, my climate control went out, and my taillights went out. I checked the fuse and it was blown, so i popped another one in. Turned the car back on, and walllaaahh, the damn fuse blew again. I was wondering is anyone knew which wires i would have to check of this problem. Im guessing it has to do with one of the wires in the center of dash where the head unit is, somewhere back there, since i installed my head unit again today, and this problem had happened to me before, but just blew the fuse and the replaced it and everything was a-ok. But this is different because the fuse just keeps blowing. TIA
the black with silver dots, like its supposed to, i just took the radio out last week and hooked everythin back up, but there was various wires in that area that were just cut, from the previous owner, but im sure i taped them all so that they mess anything up
that happen to me last week but my car is oka now. so here what i did ....i cant find what was wrong with it and it kept blowing the fuse.So i got really pissed off and i just **** it and replace the whole wire hardness system and then it works after that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue.kangaroo »</TD></TR><TR><TD CLASS="quote">which is the radio harness</TD></TR></TABLE>
Did you cut the factory harness and connect the radio wires to that? If you could take a digi pic it would help.
sorry, i have no cam
, but yes, it is cut of course i didnt cut it, the damn wire technician (sarcasm) who owned the car before me did. Yes i did wire everything up correctly, i still had my stock radio in my garage, and it on the bottom of it, it explains the wires, and i looked on my other hatch that i used to have, and figured it all out.
this happened to me at the track but i just thought my dash lights went out and then i got pulled over for no running lights but cop was cool and followed me to gas station so i could fix, so i threw another 10 amp fuse in driving down the road and bam pops agian so ill i had was a 20 amp so i stuck it in there hasnt popped since....
Well..I seemed to have fixed it. Don't ask me how. I simply don't know.
I took just about EVERYTHING apart that was even remotely connected to this circuit.
Dashboard,
heater controls,
trunk light,
right rear/brake light,
corner lights
Turns out that a nice chunk of wire had melted behind the fuse box. Replaced it. Fuses still popped.
One of my corner lights was not grounded properly, feed line touching chassis.
Fixed it. Fuses kept popping.
Replaced fuse box. No effect.
Took everything apart. Yelled, shouted, cursed, kicked the tire. Problem solved.
I'm really concerned that it's gonna start all over again, because I have no clue what the problem was. But for now...knock on wood.
Dashboard,
heater controls,
trunk light,
corner lights
When it happened to me it was my rear defogger switch that was bad... There is a lot of stuff on that same cercuit as youve found out, just check the switchs for each... All I had to do was unplug the defogger and everything worked again...
[Ennis_D]
Feb 8, 2013 06:40 PM
4g4dcruisin
51
Jul 29, 2009 02:50 PM
