will del sol si disc brake fit?
i've tried seaching and everything seems to be on integra disc brake conversions. i was just wondering if the del sol si disc brakes will fit on a eg hatch.
if yes, what parts are needed...would it be the same if i were to do a integra disc brake conversion?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B »</TD></TR><TR><TD CLASS="quote">yes... use the complete trailing arm assemblies. also use the e-brake cables.</TD></TR></TABLE>
yes and no...yes the del sol rear disc break will fit the civic...but you can't use the del sol rear disc brake E-CABLE (you could in a way use them but not going to work or fit right, cause the end of the cable toward the hand brake lever uses a "Y" style)....they are different from any other civic/integra/crx....if you can get a civic/integra E-BRAKE cable then use that..
Elijah Trevino
Jun 23, 2018 08:29 PM
310HPS2k
10
Mar 13, 2009 05:45 PM
Eg2707
Dec 21, 2006 12:45 PM
