DGTune reputation
Old Jun 3, 2026 | 01:06 PM
poomsamp's Avatar
Default DGTune reputation
Just finished an lsVtec build (b16A2 head, stock b18b bottom) and am looking for a Hondata tuner since its running really rich. I found DGTune will do a remote tune for a solid price, but I can't seem to find any reviews on reddit or anything. Anyone know about them or else another remote tuner?
Old Jun 3, 2026 | 09:33 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: DGTune reputation
Why not use a local tuner ? Where are you located ?
Old Jun 4, 2026 | 12:43 PM
poomsamp's Avatar
Mostly the price and convenience since the nearest shop I know of is 2 hours away in houston. I really just want decent mpg. Got 70 miles on half a tank
Old Jun 4, 2026 | 01:33 PM
Hadley4's Avatar
Before getting a tune, make sure there isn't a mechanical issue causing it to run rich. A tuner will get better results if everything is working properly first.
Old Jun 4, 2026 | 02:11 PM
GagnarTheUnruly's Avatar
Street tuning isn't really rocket science. I'm guessing you would need to access the ECU and datalogs yourself to get a remote tune. If that's true, since you are already running way out of spec, I recommend you do a street tune yourself ASAP. That will help you figure out what is going on and eventually you can get to Houston for a proper dyno tune. Just make sure your wideband is recording correctly, keep the AFRs close to 14.7, and the ignition timings stock and I think you can't get into too much trouble.
Old Jun 4, 2026 | 04:46 PM
poomsamp's Avatar
I've gone through a couple basemaps for different motors, b16, gsr, itr, and they all ran the same fuel-wise (rich). That makes me think it's not a problem with the tune. Any ideas? I'm considering getting a wideband O2 and maybe a new fuel pressure regulator.
Old Jun 4, 2026 | 07:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
For remote tuning, you MUST have a wideband O2 sensor installed and properly functioning so that A/F data can be reported to the tuner.
Old Jun 4, 2026 | 07:53 PM
poomsamp's Avatar
I see. Guess that's what's next then. thanks for letting me know
Rocco Cipparone
Engine Management and Tuning
Aug 16, 2023 07:55 PM
jkalex05
Nov 7, 2008 08:53 AM
boostdc
Jun 28, 2004 01:39 AM
wade
May 13, 2004 07:55 AM
rkn527
Oct 28, 2003 07:30 AM
