ARP 2000’s psi limit
Old Jun 3, 2026 | 04:36 AM
Del.slow1's Avatar
Default ARP 2000’s psi limit
I have a fully built css b18 ls vtec and unfortunately the guy I bought the motor from had arp 2000’s in it and the motor is already assembled, I’m hoping to make 800 hp and I’m wondering if any of you guys know the limit of the arp 2000’s, they are torqued to spec he said, so what psi do you guys think they will start to lift the head at? 25psi?
Old Jun 3, 2026 | 09:31 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: ARP 2000’s psi limit
A "B" Series CSS block is not rated for 800 HP... you need a true sleeved block for that level of power. ARP 2000 bolts should be associated with your connecting rods, not the head studs. Lifting the cylinder head has nothing to do with the rod bolts, although again, 800 HP is truly at the limits of what that bolt can survive. Changing to 625+ bolts requires resizing the connecting rods and may require different rod bearings. Incidentally, what connecting rods do you have ?
Old Jun 8, 2026 | 06:19 AM
Del.slow1's Avatar
The block is rated for 800hp as quoted by Jeff at css himself, and I’m not talking about rod bolts I’m talking about head studs, arp 2000 head studs
Old Jun 8, 2026 | 08:30 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Standard ARP head studs are rated for 200,000 psi tensile strength... boost pressure isn't really the benchmark and you cannot simply target that. Ignition timing, cam timing/overlap, compression (static and dynamic) all affect your maximum cylinder pressures. It will take more than 25psi of boost to make your target HP goals.
Old Jun 8, 2026 | 08:48 PM
theYBLEGAL's Avatar
Loved
This is funny this thread came up.
I just noticed speedfactory sells their own headstuds now, the 4140 210,000psi rated, and they profess 800+hp.
Arp 2000 are 220,000psi rated. So based on that math, your head studs shouldn't be the weak point.
Also, I cant find B18C ARP2000 material head studs so those must be rare-ish or may be incorrect info.
In general I see ARP 8740, ARP L19, or 4piston 625+ as options; in order of strength.
boosted k20
Dec 5, 2004 10:41 AM
boosted k20
Dec 5, 2004 09:16 AM
Dublocivic
May 14, 2004 03:38 PM
Kevin Cliff
Mar 26, 2004 05:43 PM
b16vtecsol
10
Nov 11, 2003 10:58 PM
