Select Springs Installed... now can't shift to 3rd or 5th.
Old May 15, 2026 | 10:12 PM
traction issuez's Avatar
Default Select Springs Installed... now can't shift to 3rd or 5th.
This is not a knock on Acuity. It's because I'm an idiot. I installed their selector springs in my 2002 CR-V AWD 5 speed. I managed to shift the gears as I removed the change lever assembly. After reinstalling everything, I cannot shift into 3rd or 5th/Reverse.
Does anyone know how to shift the transmission into neutral manually? As in, without the use of the change lever assembly.... I can see the shift fork assembly and I aligned them using an 3/8 extension. However, when I install the change lever assembly and install the interlock bolt (allen key), the shift cable that goes vertical does not go up at high. The change lever assembly appears to be in its neutral position as the shift arm aligned with the interlock open space. Any help is appreciated.
Old May 16, 2026 | 11:33 AM
Default Re: Select Springs Installed... now can't shift to 3rd or 5th.
I managed to fix it.
Make sure all the forks are aligned. There are three.
notsonerdy
Oct 1, 2022 02:33 PM
Bend-it
Honda Fit
Dec 4, 2013 03:15 PM
DC2_Legend
May 23, 2011 12:50 PM
WONG FRIED RICE
Apr 17, 2003 09:05 AM
The Rob
Jun 21, 2002 11:31 AM
