04 Civic back window stuck
Old Apr 23, 2026 | 06:35 AM
Brendo04's Avatar
Icon4 04 Civic back window stuck
I have a 04 civic 4d with a stuck rear left window. I tried everything to get it to go up. I tired replacing the motor and regulator, but it still wont go up. Turns out the wire that is used to connect the master switch to the rear switch that makes the window go up is bad. I don't know where exactly, and it's about to rain where I live. Is there anyway I can manually connect the two switches together (like a bypass or hotwire) to make the window go up? How do I hotwire the motor itself (in case there is no way to connect the two switches manually
Old Apr 23, 2026 | 09:30 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 04 Civic back window stuck
To raise the window, apply power (+) to the Blu/Wht motor wire and ground (-) to the Blu/Red motor wire.
To fix the issue, you would have to fix the wiring issue where the break is. Testing wires for continuity and testing for power and ground.
accord2civic2prelude
Apr 4, 2014 01:23 PM
eksedan7198
16
Mar 27, 2014 04:14 PM
bighoss77
Aug 16, 2012 08:44 PM
craiger28
Mar 22, 2009 11:58 AM
MtbikingKing
May 5, 2006 09:27 PM
