Gsr Swap (96) Into ls Integra(96)
Old Jun 18, 2024 | 07:55 PM
Cesar Zavala's Avatar
Default Gsr Swap (96) Into ls Integra(96)
Doing Gsr swap in my ls using a gsr wiring harness obd2. On the passenger side shock tower harness connectors all fit except for this forth connector, wondering what's it for. Also for vtec to engage do I need to wire the vtec solenoid to the p72 ecu even though I'm using a Gsr wiring harness or should everything be plug and play since I'm using a gsr wiring harness and p72 ecu.
Old Jun 18, 2024 | 09:46 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Gsr Swap (96) Into ls Integra(96)
What are the wire colors for the three wires in the plug you are holding ?
Old Jun 18, 2024 | 10:48 PM
Found out it's a evap plug
Old Jun 18, 2024 | 10:50 PM
But for vtec to engage do I still need to wire vtec to the ecu p72 obd2a even though I'm using the gsr harness obd2a.
Old Jun 19, 2024 | 01:08 PM
aw614's Avatar
10 Year Member
Loved
You will still need to wire VTEC to the ECU even if you have a GSR harness. The LS is missing those plugs for VTEC, IAB. Its why I went back to my LS harness+subharness for VTEC vs running the GSR harness on my car.
Old Jun 19, 2024 | 08:50 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Identify the VTS, VTP, Knock, and IAB wires on the GSR engine harness. They will likely be green/yellow, blue/black, red/blue, and pink/blue respectively. Follow them back to where the engine harness plugs into the chassis harness and then examine the chassis side plug to make sure there is a corresponding wire on that side that would connect to the needed wires discussed previously. What you should find is that these positions on the plug will be empty and have a weatherproof sealing plug in the hole instead. You can then run wires between the ECU and the chassis harness/engine harness junction and pin them to the appropriate corresponding wire location and ECU plug position.
jayxnguyen
Jul 23, 2010 08:50 PM
ricanxplaya
Jun 24, 2010 05:09 PM
myjdmsucks
Oct 5, 2006 03:56 PM
kingrat
Feb 14, 2003 11:00 AM
