Can you use an alternator from a 2.0 engine on a 2.2?
![Icon5](https://honda-tech.com/forums/images/icons/icon5.gif)
I need a new alternator for my 1995 Accord Coupe 2.2, and found one used from a 1996 Accord (CE, CF) with a 2.0 engine.
Will the alternator from that be powerful enough? I'm not very knowledgeable about this.
Premium Member
![Default](https://honda-tech.com/forums/images/icons/icon1.gif)
If the plugs at the voltage regulator are the same then it will work. Although the rated outputs may be different.
