93 del so clock not working.
Old 05-17-2024, 04:42 PM
Damien B.'s Avatar
Default 93 del so clock not working.
I have a 93 del so and the clock doesnt work. I was wondering if the power wire for the radio amd the clock are the same wire. You can press a button on the clock and get a flicker but no display. I did have to run a wire to the radio because the origonal was only putting out about 6v, witch wasnt enough to power the headunit, i do suspect the dash to not be the orignal to the car as the vin on the dash do not match the vin on the firewall. Any feedback is much appreciated.
thanks, Damien.
Old 05-17-2024, 10:58 PM
95_civic_gsr's Avatar
Default Re: 93 del so clock not working.
Check your under hood fuse box. Its either the ECU or ECU/ECM back up fuse that also powers the clock.
DelSolMike
05-23-2014 02:52 AM
kensaysrawr
05-24-2012 05:33 PM
93delsolrunner
05-14-2008 01:23 PM
hbracer93
11
02-04-2006 06:25 AM
Quick Reply: 93 del so clock not working.
