ignition control module
Old 07-12-2019, 05:22 PM
StevoDVS's Avatar
Default ignition control module
98 Honda Civic EX (Auto-to-Manual) with 95 GSR swap; OBD1 ecu with jumper harness to OBD2 Civic EX harness. distributor is TD-87U.
aside from OEM/Stealership, where would be the best place/shop/parts store to get a Ignition Control Module replacement??
Mahalo in advance!!
Old 07-12-2019, 06:03 PM
muellersfan's Avatar
Default Re: ignition control module
Why do you want to replace it?
Old 07-12-2019, 07:58 PM
StevoDVS's Avatar
coupe is dying out while driving. it just shuts down. been researching and this is 'one' of the culprits.
Old 07-12-2019, 08:09 PM
Could be the ICM.
When the engine stalls, does it always restart immediately?
Old 07-12-2019, 09:01 PM
StevoDVS's Avatar
Originally Posted by muellersfan
Could be the ICM.
no it doesn't. gotta let it sit for 5-10 minutes before it'll start up again. yeah, i was coming to the conclusion that it could be the Ignition Control Module aka ICM?? just hoping that i could get a recommendation on which is the better one to get other than OEM.
Old 07-12-2019, 09:16 PM
Could be ICM, coil, or something else. When the engine won't start immediately, check for spark at the plugs. If there's no spark, then you may be on the right track, if the coil is good.
You could buy online from Amazon or Rockauto.
Or any local auto parts stores, though they'll generally be more expensive.
Old 07-12-2019, 09:36 PM
StevoDVS's Avatar
much mahalo @muellersfan !!!
Old 07-15-2019, 08:31 PM
California98Civ's Avatar
Years ago I had this problem on my 98 Civic DX. I first diagnosed it as ICM. Wrong. Was coil. Got a replacement (the whole distributor, I think) from Autozone and the problem has never recurred yet. When the coil got hot after some time driving (not just warm up) it would expand from heat and temporarily fail. Waiting 10 mins gave it time to cool and contract and it would run alright again.
Old 07-20-2019, 01:44 AM
StevoDVS's Avatar
damn! i was just thinking about swapping out the whole distributor too. i'm kinda stuck on the whole 'OEM' deal but sometimes it's just way too expensive. smh. gotta pay to play, right? thanks for the info; i may end up just getting the distributor. we'll see.
Old 07-20-2019, 04:57 AM
Keep the Honda distributor. It can be rebuilt. Nothing else comes close.
Old 07-20-2019, 08:35 PM
JRCivic1's Avatar
This is an incredibly important statement. The factory distributor housings are WAY better than aftermarket ones... so if you have an ICM or coil failure, replace it and don't junk the dizzy. The aftermarket crap is cheap junk.
Old 07-21-2019, 05:51 PM
StevoDVS's Avatar
totally agree!!! and most definitely will not be getting rid of that bad boy!!
Old 07-21-2019, 05:56 PM
StevoDVS's Avatar
yup most def agree with @muellersfan statement!! and yes that's what i totally wanna do is rebuild my distributor but was looking for other options with the ICM and COIL to be replaced. and I SHOULD KNOW BETTER than to just stick with OEM as much as possible...it's just that cost tho lmao
Old 07-21-2019, 07:13 PM
JRCivic1's Avatar
Actually, I have had exceptional luck with the Accele replacement coils which are more affordable than OE and you can get NEC and Tec ICM's in the aftermarket for less money as well. The KEY to making a replacement ICM last long term is to use a liberal amount of conductive paste between the ICM and the heat-sink during installation.
Old 07-22-2019, 12:43 AM
StevoDVS's Avatar
thanks, man!! money is kinda tight atm so i'll def check into the accele replacement coils. i also gotta remember to put that 'liberal' amount of conducive paste as well when swapping out the ICM.
stephenjr321
10-10-2018 04:31 PM
jojo69
10-23-2006 05:23 PM
92siracer
05-20-2004 11:42 PM
Quick Reply: ignition control module
