CR-V engine oil problem
Old 06-20-2019, 05:40 AM
DMRoot's Avatar
Icon5 CR-V engine oil problem
13 CR-V, synthetic oil and filter changed at proper intervals since new.
around 93,000 . Rattles a lot at start up.
Anything available for help?
David
Old 06-20-2019, 06:05 AM
shipo's Avatar
Default Re: CR-V engine oil problem
David
Is it the engine rattling, or could it be a heat shield or something related to the serpentine belt?
Old 06-20-2019, 06:16 AM
DMRoot's Avatar
Its the engine. We also have a 2016. We changed the oil in the 2016 using 0-20. Initial startup had a rattle that I know for a second or two. Oil not circulating until filter is full etc, The 2013 makes the same sound after it sits a few hours then started. Tried some 5W30, no change. Going back to 0-20.
If its been started, re start makes no noise. If it sits over night, makes a helofa clatter for the first second or three.
David
Old 06-20-2019, 07:53 AM
shipo's Avatar
David
I have had a couple of cars over the years where there was pronounced start-up clatter; I ended up discovering it was the oil filter's "Anti-Drainback Valve" (ADV) which was the culprit. The thing is, some engines have an integrated ADV; many rely on the oil filter for that function. My advice would be to try a different brand filter and see if that helps.
Old 06-20-2019, 07:55 AM
DMRoot's Avatar
I will try a different filter.
David
Old 06-20-2019, 07:59 AM
1999 Civic Si's Avatar
This sounds a lot like the VCT Solenoid/Actuator, there is TSB for the 12-13 CRVs on it, I don't know if they extended it to cover any of the newer CRVs. But based off your description its seems to match, can you tell where the sound is coming from if you have the hood open and are standing in front of the car listening?
Filters are cheap though, so it doesn't hurt to replace that to make sure.
Old 06-24-2019, 07:44 AM
DMRoot's Avatar
I put a Honda filter with no change.
Going to listen with hood open. It needs to sit a half hour or so.
Sounds like "Shot engine " to me.
David
Old 06-24-2019, 08:06 AM
David
If you haven't already I would look into the TSB I mentioned in the above post. Don't want to jump to the conclusion of a shot engine before looking into a known issue. The sound that VCT actuator makes can be nasty sounding.
Old 06-24-2019, 08:57 AM
shipo's Avatar
David
Start-up clatter does not in any way equate a "shot engine".
Old 06-25-2019, 05:28 AM
DMRoot's Avatar
Yes, its in the top of the engine, Looking at the TSB.
Thank you
David
Edit: Ordered an actuator Hope to put it in Thursday.
Thanks for the TSB!
Old 07-02-2019, 06:25 AM
DMRoot's Avatar
Replaced the cam shaft gear. All is well, thank you for putting up with me.
Took a couple hours, part was $115.00 local.
David
