Light weight battery recommendation
Old 06-14-2019, 07:03 AM
LankorDie's Avatar
Icon5 Light weight battery recommendation
I picked up a Oddssey PC680 since that was the standard battery people ran. I personally have had great luck in the past with this battery. After a little over a year the battery is already dead.
Amazon reviews are saying that you are lucky to get a year out of PC680's now days...
I need the battery in front of the firewall, OEM location is now intercooler piping.
Suggestions?
Old 06-14-2019, 10:59 AM
LankorDie's Avatar
Default Re: Light weight battery recommendation
Solved this issue.
Please close.
P.s. All the shops I called that sell Oddssey PC680's said they are having the same issue. Less than a year life on the batteries.
Old 06-14-2019, 11:14 AM
scelestus's Avatar
How did you solve it?
I was hoping there would be a few replies here, I've found a lot of conflicting info and wanted to get some insights.
Old 06-17-2019, 06:26 AM
LankorDie's Avatar
I did find a solution.
Called up James the Ktuned ITR TA driver, he said they have been running ATX20 batteries for a while.
https://shop.antigravitybatteries.co...-oem/atx20-rs/
A little more expensive but weighs 4 pounds, drain protection, LI
Old 06-17-2019, 09:04 AM
Tyson's Avatar
um, what side is positive?
Old 06-17-2019, 12:26 PM
tommycrx's Avatar
I have no idea - I guess you just do rock-paper-scissors and hope for the best. That's truly bizarre.
Old 06-17-2019, 04:16 PM
DaX
DaX's Avatar
Old 06-17-2019, 04:26 PM
LankorDie's Avatar
Whats the problem here? Its clearly marked, and you get two of each terminal.
Old 06-17-2019, 04:38 PM
CD8
CD8's Avatar
I had an odyssey die in about a year, and they replaced it for free....
Old 06-17-2019, 04:49 PM
turbociv910's Avatar
pc925 in my street car
Old 06-17-2019, 08:51 PM
acmoc's Avatar
I'm still confused
Old 06-18-2019, 08:24 AM
tommycrx's Avatar
Look at the third pic on their site; the colored indications under the "ANTIGRAVITY" are the opposite of the indications at the posts.
Old 06-18-2019, 08:57 AM
LankorDie's Avatar
That is very odd, not sure if it's part of their logo, but confusion is understandable.
Old 06-18-2019, 09:20 AM
Tyson's Avatar
guys, its just a poorly photoshopped decal. but its hosted on their site. a mistake and i'm sure whatever they ship is going to be labelled properly, and easily checked.
it was just a joke, kinda concerning, but still not serious.
Old 06-18-2019, 01:31 PM
tommycrx's Avatar
Ok, you put one in your CRX first, Tyson. It's a Y49 anyway.
Old 06-18-2019, 06:26 PM
Steve at Heart
Bently_Coop's Avatar
You guy's seen the @Hasport
@hush22 PC680 bracket? It mounts inside the fender well.
Speedfactory Racing sells the XS D680 with a bit higher amperage.
https://4xspower.com/shop/12v-agm/d-series/d680/
Old 06-18-2019, 06:37 PM
CD8
CD8's Avatar
I was going to do the hush relocation but i dont want to have to add a master cutoff switch
Old 06-18-2019, 09:23 PM
acmoc's Avatar
Does anybody weigh their cars and know the best place to place the battery to balance the weight?
Old 06-19-2019, 05:36 AM
LankorDie's Avatar
This is the best EF battery bracket I came across. I would run it if it wasn't for my FMIC piping being in the way.
Old 06-29-2019, 09:10 AM
hush22's Avatar
Thank you for the tag!
