Honda Pilot 2003 parasitic battery drain
I have a Honda Pilot with a parasitic battery drain that kills battery after a day or two. Using a mulitmeter i traced it down to fuse 13 in passenger side fuse box where I was getting about .09 amps with key off and everything else off. Pulled fuse and it is so far not draining battery anymore. This fuse is labeled "back up" and is 7.5 amp fuse. Any ideas as to what this goes to or what could be causing the drain?
