Laile Beatrush EG hatch Under Panel on an EG Civic sedan (4-door), does it fit?
Just wondering if anyone has tried to fit the Laile Beatrush EG6 (hatch) front under panel to a sedan and how'd it go?
I know the hatch front is shorther than the sedan but, I thought the panels were still interchangeable... maybe? If that is correct, I assume the underlying front body structure where an under panel would mount would be the same between the sedan and hatch. Any insight would be appreciated.
Laile Cooling Under Panel
Oh look, I can change this
Re: Laile Beatrush EG hatch Under Panel on an EG Civic sedan (4-door), does it fit?
Pretty much it's just cosmetic body panel differences up front. Under the hood, though, they are similar. For example you can swap a hatch rad support into a sedan .... iirc (check part numbers though). So I'd guess they are structurally similar enough for an application underneath like this that it wouldn't make a difference.
flatblk
09-20-2006 03:53 PM
