96 Integra coupe wiring puzzle
Old 10-19-2017, 08:04 AM
lolv8s's Avatar
Default 96 Integra coupe wiring puzzle
Ok, first off. I destroyed my wiring when I got this shell when I was 16. I cut the passenger side wiring harness at the firewall intending to tuck the wiring some day. Anyways 5 years later I have the swap built and put in. I replaced the dash harness with a 99 obd2a dash harness. Or so the guy said on eBay. I did this to myself I know. So that’s under dash fuse box and all. I’ve plugged in everything that matches so far. But I still have some plugs that I can’t find a match. I’ll post pics. But it’s starting to look like I’m better off getting a new shell with wiring already matching and take out all of the mods I have and swap over. I just placed my thermostat ground. valve cover ground. Lights come on but blinkers don’t blink. Main relay doesn’t click. Im lost....
Old 10-19-2017, 08:06 AM
lolv8s's Avatar
Default Re: 96 Integra coupe wiring puzzle
Is this the right plug for the brake pedal sensor?
Old 10-19-2017, 08:13 AM
lolv8s's Avatar
No idea with this one. Comes off of the dash harness right where it turns towards the fuse box under the dash. By the driver side headight harness.
Old 10-19-2017, 08:16 AM
lolv8s's Avatar
I got this shell with a clutch pedal sensor broke. But I can line up the terminals in the mean time to guess where the wiring goes. Am I right?
Old 10-19-2017, 08:23 AM
lolv8s's Avatar
no clue with this green black one.
Old 10-19-2017, 04:15 PM
tamboo's Avatar
will pm you a link to the helm manuals including electrical troubleshooting. good luck...
Old 10-20-2017, 12:10 PM
lolv8s's Avatar
does anyone know of any shops they could suggest that work on wiring like this in the Dallas/ DFW area?
Old 10-22-2017, 11:14 AM
lolv8s's Avatar
my high and low beams work. I’ve grounded the engine harness. Thermostat. But I still can’t get the relay to click or fuel pump to prime. I think these dash harnesses might be incompatible?
Old 10-22-2017, 04:20 PM
tamboo's Avatar
call these dudes in garland, they got a stellar rep.
no doubt they can recommend somebody. 972-494-2100
Jotech Motorsports - The 20 Best Import Tuner Shops in America | Complex
Old 10-22-2017, 10:48 PM
lolv8s's Avatar
Jotech Motorsports - The 20 Best Import Tuner Shops in America Complex
righto good idea. I got Hondata put in my Ecu from jotech. Best service I’ve had. After I wanna put my turbo on it’s going to jotech.
Old 10-24-2017, 08:07 AM
lolv8s's Avatar
they told me they just don’t really do wiring anymore and wasn’t sure if someone to suggest. So what I think I need to do is get a wiring harness out of a 96 model Integra. But it would take forever to find a manual Integra harness. An auto harness would be a quick find. I guess I could make a 96 auto harness work because people do the auto- manual conversion and keep the harness. I just wish I could find an electrical shop I could just take the car to. Wiring is something I only know so much about.
Old 10-24-2017, 03:06 PM
lolv8s's Avatar
I guess I’ll get a 96 dash harness to match. I’m sure I’ll end up with an auto harness because manual is harder to find. But I question how will I plug into clutch pedal? I need to find out if I have obd2a or b. Then I’ll find a dash harness to match. But another question is what engine harness I would need. I have a b18a1 in my 1996 obd2 Integra.
Old 10-24-2017, 03:53 PM
tamboo's Avatar
ok here's some other guys to chat with.
https://www.yelp.com/search?cflt=aut...s%2C+TX%2C+USA
freeman honda is supposed to be good too.
Old 11-03-2017, 09:46 AM
lolv8s's Avatar
I went to a dealership and this guy told me the most cost effective thing for me to do would be to get another shell and swap everything. I had a “can of worms” so to speak. if anyone could make me a checklist on wires/ fuses, connections/ etc for the main relay, before I get another shell. I would greatly appreciate it!!!
Old 11-03-2017, 01:28 PM
MotorMouth93's Avatar
I don't think this is worth buying a new shell over yet.
That grey plug with a bunch of pins by the clutch pedal is for the cruise control computer, it shouldn't matter.
I see this as more of a main relay issue than a wiring harness issue. The main relay itself isn't particularly complex, it only has a couple wires going to it, so you just have to make sure they go to the right places.
Pin #1: BAT+, use a multimeter and make sure this pin has battery voltage.
Pin #2: GROUND, use a multimeter set on the continuity checker and make sure this pin is shorted to ground.
Pin #3: ECU, multimeter on continuity mode, make sure this pin is connected to ECU pin A25 for OBD1 ECUs.
Pin #4: Starter signal from key, when the key is in the cranking position this should have battery voltage.
Pin #5: When the ignition is on, this should have battery voltage.
Pin #7: Fuel pump power, using the continuity setting make sure your fuel pump is connected to this.
Pin #8: ECU, fuel pump relay, make sure it's connected to ECU pin A7 for OBD1 ECUs.
Also go ahead and test your clutch pedal and brake pedal sensors (continuity setting on multimeter)
Old 11-04-2017, 11:59 AM
qfast817's Avatar
What part of dfw are you in? I can look and see if I have a spare harness off my 96 gsr, it was cut when they messed up a alarm stall but can be fixed only 4 wires.
Old 11-06-2017, 06:27 AM
lolv8s's Avatar
I’ll get started on this. Thanks!!! Cheers
lolv8s
11-02-2016 04:44 PM
gummiegorilla
07-30-2009 07:32 PM
19_lude_s_96
03-04-2006 02:27 PM
eagleclawracing
01-24-2006 04:09 PM
Quick Reply: 96 Integra coupe wiring puzzle
