Little to no brake pedal a few weeks after I bleed the brakes
About a month ago, I had to replace my master cylinder in my 1993 honda civic because it was leaking brake fluid rapidly. After replacing it I bleed just the front 2 calipers to and everything was good, I had pedal again and no leaks. Well yesterday I was driving my car, and I go to press the brake and it went almost all the way down to the floor easily, but luckily it still stopped like normal. When I got home, I checked the Master Cylinder for fluid and it was still full, it hasn't lost any fluid or anything. I haven't done anything yet, mainly because I wanted to know what could of caused it to do something like that, and also if I did anything wrong when bleeding before. Is it possible something else failed? Thanks for any input.
Re: Little to no brake pedal a few weeks after I bleed the brakes
For peace of mind you should bleed all four starting with the one farthest from the MC and work your way forward, while down there check your brake lines/hoses for any wet or damp spots, once youve eliminated that issue then you can move on to the MC, double check everything. If equipped with ABS then bleed it also, theres not much to the braking system just spend some time to look it over, should go quick for you, good luck.
Just something that comes to mind: When you replaced the MC, did you fill with a brand new just-opened bottle of brake fluid, or a bottle that had been opened a while ago?
New mc require bench bleed. Was it done?
You still have air in the system. Go back and bleed all four corners.
I'm just confused why it took a month to do something like this, I'm assuming it's because the brake pads have wore down a bit and air was still in the system or something, but I thought it would of been noticeable that day when I was bleeding the brakes. Anyway, I will give you guys an update tomorrow after it's finished!
Engine running, press the brake pedal and hold it. If it slowly sinks to the floor, and you're not leaking brake fluid anywhere, the master cylinder is bad. Likely to happen with a chain store part.
Ok, so quick update, today I was going to head out to bleed my brakes so I get in my car to move it into my garage, and my car has brake pedal again???? I went to drive it and it was back to normal, can anyone explain to me what can cause that, because the last thing I need is it to lose pedal while I'm driving it. I haven't done anything to it at all, it's just fixed???
Quick update, we went to bleed the lines on Tuesday, but their was so much air in the line that we just thought we might as well get a brake bleeder, we got one on Wednesday from Harbor Freight and we were able to knock out the back right brake line in about 20 minutes, we did the front 2 and now we are at the back left and we are getting fluid but their is a lot of air bubbles, so we waited to finish it today since it was getting late, we went back to do it today and it's been doing the same thing for over an hour now, and it has been going at the same rate for about an hour now. Is it possible something is wrong with the line itself?
So, I'm pretty sure whatever is causing my issue is with my back right brake line or something, when I got the issue, the back right brake line, had almost nothing in it, when using a brake bleeder kit, I was able to get fluid back there, however it looks like it still has a bunch of air in the lines and I've gone through 2 bottles of fluid now with no change. Does anyone know what could be causing this?
You have a leak somewhere back there. Either at the bleeding screw or at the hardline. Air is entering the system, hence the bubbles. System is open somewhere.
90 integraian
Suspension & Brakes
09-25-2008 05:11 AM
