2005 civic lx 4 door Alignment issue
I have a 2005 honda civic lx 4 door, and I brought it in to get aligned because it was pulling to the right with a crooked steering wheel.
They aligned it and and said there might still be a small pull because of the right rear camber.
My car is completely stock and not lowered, Would it require a rear adjustable camber kit to correct this issue with the rear right camber?
Here are my before and after specs
BEFORE
AFTER
BEFORE
AFTER
Re: 2005 civic lx 4 door Alignment issue
what's the verdict after the alignment, is it still pulling ? you got lucky when they adjusted the toe 'cause it barely brought camber into specs
