What is this rattling noise, valve train?
Old 05-21-2017, 04:18 PM
alextech's Avatar
Default What is this rattling noise, valve train?
I have a honda civic 98 with a y8 motor and a z6 head. The rattling noise started happening after I fixed the AC. I drove it on the freeway and I had to press the gas hard and it did not want to accelerate with AC on and now I have a rattling noise. I dont know exactly what the noise could be. Could it be the valve train or the pistons perhaps? Here is the video:
Old 05-21-2017, 05:45 PM
mk378's Avatar
Default Re: What is this rattling noise, valve train?
Acts like it's running on 3 cylinders. Disconnect fuel injectors one at a time while idling to see if there is a dead cylinder.
Old 05-21-2017, 07:12 PM
Nedrobmas's Avatar
How did you fixed the a/c? If you took something apart, start there. Did you leave any
Old 05-22-2017, 06:02 AM
alextech's Avatar
I replaced the AC compressor and the expansion valve with a new one. I will look further and see what I find.
Old 05-22-2017, 07:35 AM
alextech's Avatar
I checked each spark plug and they all have spark, I am starting to think its just the motor.
Old 05-22-2017, 06:15 PM
alextech's Avatar
My distributor cap is kind of loose, could this have been the cause? I will check tomorrow.
Old 05-22-2017, 07:13 PM
Nedrobmas's Avatar
Maybe, did you mess with it when you did the installation? I would recheck everything you touched. Maybe there's a tool banging around down there. Double check all the bolts and screws you tighten are tighten. Check the tension in the belt, motor mounts you took off if you had too. Check everything single thing from the time you used the your first tool to the last. How do the a/c feel?
Old 05-22-2017, 07:40 PM
wxman94ej1's Avatar
Did you replace the belt that drives the A/C compressor? I don't know how the tensioner works for that belt but could be the belt slightly mis-aligned or mis-tensioned and hitting something you can't see.
Old 05-26-2017, 07:27 AM
alextech's Avatar
The AC is not that cold, I am thinking it could be the drier yhats causing these problems?
Old 05-26-2017, 12:13 PM
wxman94ej1's Avatar
The drier is a passive part- there are no moving parts in it or attached to it. It could cause a/c to not be as cold as it should be but It seems like the drier would be unrelated to your rattling noise. Did you check the belt like I suggested?
Old 05-27-2017, 02:22 AM
White_EG1's Avatar
This looks like the result of a poorly put together mini me. Plus it's never good to use the z6 head on a y8 block, timing can be close with a aftermarket cam gear but never correct. Timing was probably never set even close to spec and bent a valve, soon it will drop and seize the motor.
Old 06-21-2017, 11:58 AM
alextech's Avatar
I think you are right, timing was set but it might now have not been exact exact timing. And I am convinced the motor's crankshaft bearing is what I am hearing. I found a really cheap y7 engine, might as well just downgrade and sell it. Also, I have noticed the engine accelerates by itself in the freeway but only with the AC on. I forgot to mention that it does have an error code for the knock sensor. I had just found out that this knock sensor is not OEM, and that is why I am getting the code. I didnt think the knock sensor would be so important.
gooeymax
08-30-2018 04:33 AM
guymontag
02-20-2016 01:38 AM
TOO MUCH TORQUE
06-01-2013 12:11 PM
jrock1234
06-04-2012 12:26 PM
dom93hatch
01-28-2005 08:18 PM
Quick Reply: What is this rattling noise, valve train?
