Multiple problems with 99' Honda Accord
- Speedometer doesn't function
- Shifter light, a/c backlit lights, instrument cluster lights* don't function
- Jumps/sputters when driving
- Fast left turn signal
1) I used this youtube video
3) When I'm driving after about 30min when you step on the gas (I have a heavy foot) when it normally accelerates it starts to jump. I'm not sure how to describe it, it like a jerking motion. It stops when you let go of the gas and then ease into the desired speed.
4) The turn signal flashes fast; I've checked all the fuses and all of them are there and are fine. I have changed the bulbs for that whole side.
* Needs a knock sensor replacing soon
Re: Multiple problems with 99' Honda Accord
Does the check engine light function? Is it on steady? Does it ever flash while driving? Do you know if you have any stored codes?
Have you checked for a signal output from your headlight switch for you dash illumination? I don't remember, is your dimmer on the dash or the cluster? You need to check there also.
Good luck!
Good luck!
Have you had the codes checked to find out shh the check engine light is on? You mentioned a knock sensor. If it is bad it could be causing all sorts of problems.
JozeF23
01-26-2014 12:38 PM
Tyla12
05-28-2010 09:00 AM
