2003 Accord Vibration
Old 06-11-2011, 01:38 PM
dtrophy's Avatar
Default 2003 Accord Vibration
I have a 2003 Honda Accord. It has a vibration that is barely noticible until you reach speeds near 60 MPH. At 60 MPH it has a bad vibration from the front end that requires you to slow down to stop the shaking. The interesting thing is that the vibration disappears when you let off the accelerator, even if you are still at 60 MPH. The vibration is only while accelerating. I had the tires rotated and balanced this morning. It may have helped a little, but not much. Anyone have any ideas? Any help will be appreciated.
Old 06-11-2011, 06:41 PM
03djmAccrd's Avatar
Default Re: 2003 Accord Vibration
Has anyone reccomended an alignment?
Old 06-13-2011, 07:59 PM
SlowCG's Avatar
Potentially bent axles
Old 12-08-2011, 10:52 AM
mkarbeling's Avatar
I had this problem also, (at 50-55 and up when I accelerated, the whole car vibrated) and it was getting worse and worse over the past 3,000 miles. I tried replacing tires, re-balancing +and rotating tires. Finally a shop found that both axles had to be replaced. (Honda dealer insisted it was tires).
This is apparently a very common problem on 2003-5 Honda Accords.
Gulp the cost was $560 but it rides great now and handles much better. There were flat spots on both CV joint bearings and the axles were sealed and as a unit had to be replaced with the CV joints and boots on both rt and left axles.
Old 06-25-2012, 07:19 AM
triviaace's Avatar
I'm having the same problem with my 2004 Accord. My local Honda dealer has been providing all my service since I bought the car new. He quoted me a price of about $1000 to have the work that you described done. My question is "did you have your work done at a Honda dealer and when?" since the cost he asked is almost double what you paid. Thank you.
Old 08-19-2016, 05:48 PM
dankaes's Avatar
Old 08-19-2016, 05:53 PM
dankaes's Avatar
In any steering shake whether low speed high speed
Check inner & outer tie rods
Ball joints control arm bushings
Tires
And axle and bearing
If all look good
The axles are your vibration
During acceration
Old 04-26-2017, 09:24 AM
Wrobertson38's Avatar
I also have this same Vibration in my 03 Accord EX. Replaced: Coil packs,plugs,driver and pass lower control arms and passenger axle. No change except after the axle. The vibration got worse. going to try the driver axle next. Any input ???? anyone????
Old 04-26-2017, 09:30 AM
Icon6 Re: 2003 Accord Vibration
I also have this same Vibration in my 03 Accord EX. Replaced: Coil packs,plugs,driver and pass lower control arms and passenger axle. No change except after the axle. The vibration got worse. going to try the driver axle next. Any input ???? anyone???? ?
Old 04-30-2017, 12:36 PM
user456101's Avatar
With vibrations that only start at a certain speed the first thing to check is the tire balancing. If that doesn't fix it, you can check the suspension yourself to some extent. Watch Scotty Kilmer YouTube video "How to check your own cars suspension system". Scotty has been a mechanic for 49 years. It is also fairly cheap and easy and safe to replace the CV axles yourself with non OEM parts from a place like AutoZone or other parts store, says Scotty in another video "Replacing a broken CV axle on your car"
GerryH
01-23-2017 05:08 PM
KhornLuda
11-29-2012 07:23 AM
NGUSPEED
01-11-2012 06:39 PM
speeddog
04-08-2009 01:56 PM
BodyKits NW
01-06-2006 08:13 PM
Quick Reply: 2003 Accord Vibration
