F22B2 coil question
Old Apr 19, 2009 | 03:58 PM
extremevtecracing's Avatar
Default F22B2 coil question
Okay first off, what is the green wire in the 4 pin plug that goes to the coil and wtf is its purpose in life. Here is why I ask. I have an accord I been looking at for my neighbor due to no spark. I disconnected the coil wire and arched it to see if it sparked and nothing. Obviously the black and yellow wires are 12v and ground and I checked them and they are good. But I have no clue what the green does and its purpose. So any ideas on the would be swell.
Old Apr 19, 2009 | 07:04 PM
GhostAccord's Avatar
Default Re: F22B2 coil question
The green wire is the primary output control wire. With the key on engine not running, you should see 12v between it and body ground . This test checks battery voltage from the coil.
Have you tested the coils resistance?
Coil Connector
|A-B|
|C-D|
Primary coil resistance between pin A & C should be 0.6 - 0.8 ohms
Secondary coil resistance between pin A & Secondary winding terminal (coil wire connection) should be 14 - 22 K-ohms
Were you have tested the 12v ignition source and it's Good. If the coil checks out, and your still not getting spark. I would say your looking at replacing the ignition control module (ICM aka Ignitor).
Old Apr 14, 2026 | 04:39 AM
Robert Arauz's Avatar
5 Year Member
Coil Connector
|A-B|
|C-D|
96 service manual F22B2 MOTER says A to B 0.64 to 0.78 ohms A to C continuity and nothing else. page 23-104
Old Apr 19, 2026 | 11:56 AM
tedmak's Avatar
Yes it does:
Primary Winding Resistance (Between the A and B terminals):
0.64 - 0.78 Ohm
Secondary Winding Resistance (Between the A and secondary winding terminals):
14.4-21.6 Ohm
Check for continuity between the A and C terminals.
I would post a screenshot from the manual here but I'm not sure if it's allowed by the forum rules because of copyrights etc.
senor honda
Dec 23, 2010 02:27 PM
Horseofcourse
Apr 11, 2008 10:33 AM
Silver.007
Oct 12, 2005 06:50 AM
vteckilla7
Aug 18, 2004 06:29 AM
vteckilla7
Aug 8, 2004 01:41 PM
