Clutch master cylinder and slave interchangeable ( civic and integra )
Old Sep 24, 2007 | 11:57 AM
FuNkDrSpOt's Avatar
Default Clutch master cylinder and slave interchangeable ( civic and integra )
are they? I couldn't find out by searching.
Old Sep 24, 2007 | 01:30 PM
Relic1's Avatar
as far as a custom application, they should be. as far as bolt on, nope.
If you're going that custom you should be mapping out the travel of the cylinders. So take close note of the piston sizes, the master-to-slave ratio may be different.
A larger master would result in more travel in the slave per travel of the master.
Old Sep 24, 2007 | 01:54 PM
Luserkid's Avatar
Default Re: (Relic1)
From my understanding, Integra and Civic clutch master cylinder and slave are all the same.
Old Sep 24, 2007 | 02:26 PM
FuNkDrSpOt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">as far as a custom application, they should be. as far as bolt on, nope.
A larger master would result in more travel in the slave per travel of the master.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">From my understanding, Integra and Civic clutch master cylinder and slave are all the same. </TD></TR></TABLE>
anyone else have first hand info on this?
Old Sep 25, 2007 | 11:50 AM
FuNkDrSpOt's Avatar
Default Re: (Luserkid)
So does anyone know?
Also, does anyone know what the part #'s for the clutch master cylinder and the slave cylinder are?
I have an '97 eK chassis and a '97 gsr engine.
Old Sep 25, 2007 | 11:53 AM
fmrprojects's Avatar
Default Re: (FuNkDrSpOt)
yes they are the same i swapped integras on civics before and it works the same
Old Sep 25, 2007 | 11:55 AM
kuja396's Avatar
Default Re: (fmrprojects)
Thats what I thought
Old Sep 25, 2007 | 12:16 PM
FuNkDrSpOt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">From my understanding, Integra and Civic clutch master cylinder and slave are all the same. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kuja396 &raquo;</TD></TR><TR><TD CLASS="quote">
Thats what I thought</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">yes they are the same i swapped integras on civics before and it works the same</TD></TR></TABLE>
I figured Luserkid was right but I just wanted to get a more definite answer. Cool peoples! At least this thread should pop up from now on when people search to see if they are.
Old Sep 25, 2007 | 12:27 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt &raquo;</TD></TR><TR><TD CLASS="quote">
I figured Luserkid was right but I just wanted to get a more definite answer. Cool peoples! At least this thread should pop up from now on when people search to see if they are.</TD></TR></TABLE>
ignore my response...for some reason I read that as you wanted to use a slave as a master or a master as a slave.
not from civic to teg.
Old Sep 25, 2007 | 01:43 PM
FuNkDrSpOt's Avatar
anyone know the part #'s?
Old Sep 25, 2007 | 01:48 PM
Luserkid's Avatar
CMC: 46920-S04-A01
SMC: 46930-SR3-013
Old Sep 25, 2007 | 04:11 PM
FuNkDrSpOt's Avatar
This forum needs rep ratings so i can give you props for helping me out for like the 10th time, Luserkid
Old Sep 27, 2007 | 05:29 PM
6gSI's Avatar
this answered my question i think...
my 99 Civic SI has a B18c swap, and i was wondering if there was a difference between the civic slave and master vrs the integra slave and master...
Old Sep 21, 2011 | 08:34 AM
typeflex's Avatar
Default Re: Clutch master cylinder and slave interchangeable ( civic and integra )
this was the exact thread I was looking for, good information.
Old May 7, 2026 | 05:40 PM
CheifBeef's Avatar
Does this apply to a civic and integra that are both 95?
Old May 7, 2026 | 08:06 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It sure does.
Hyoriu
Apr 16, 2009 09:10 AM
B18CJDM
Mar 15, 2002 07:28 PM
