Where is this small cylinder thing from? (Pics)
Old Apr 3, 2018 | 03:58 PM
K-G's Avatar
K-G
Default Where is this small cylinder thing from? (Pics)
This is my first rebuild.
dropped my d16 head off at the machiene shop and when I brought it home I found this in the bag.
Where does it go ?
Old Apr 3, 2018 | 04:21 PM
mk378's Avatar
Default Re: Where is this small cylinder thing from? (Pics)
Is it solid?
There are two hollow cylinders about that size that align the head with the block. They fit in two of the front (exhaust side) head bolt holes. Put them in the block (they go in halfway) then push the head gasket down over them to hold the gasket in position, then put the head on. The bolt of course goes through the hollow center.
If it is solid you should ask them where it came from. I think it may have something to do with the VTEC in the rocker arms, but I've never taken one apart that far.
Old Apr 3, 2018 | 04:28 PM
K-G's Avatar
K-G
Originally Posted by mk378
Is it solid?
yes it is solid. Small also. If you are describing the dowel pins that’s not what it is
Old Apr 3, 2018 | 04:30 PM
K-G's Avatar
K-G
unless it’s used in conjunction with them. But didn’t see it when I took the head before. Only after
Old Apr 3, 2018 | 07:07 PM
jdblock's Avatar
Look through a Honda parts catalog for your car. Bet you can find where it goes that way.
Old Apr 3, 2018 | 08:57 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It is a VTEC rocker arm pin... so check all of your rocker arms and see which one is missing the pin. If there is more than one missing... contact the machine shop and find the rest. If even ONE of these is missing when the engine is assembled, VTEC will NOT work.
Old Apr 4, 2018 | 02:29 AM
K-G's Avatar
K-G
you are the mannn. Thank you very much for that info
Old Apr 4, 2018 | 06:05 AM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
^^^What I was going to say^^^
Old Apr 4, 2018 | 06:58 AM
09chaplak's Avatar
Loves Tossing Salad
samesies
Old Apr 4, 2018 | 08:38 AM
K-G's Avatar
K-G
Thanks for the help guys. Was able to pull the assembly off and the first thing I noticed was a big empty spot. It was this one right here. Really appreciate the help guys. None of the others seem to be missing
Old Apr 4, 2018 | 09:18 AM
CX-Adam's Avatar
talks to himself
Community Builder
RSSEXtype-sizzle
Aug 12, 2012 09:46 PM
Br1t1shguy
Dec 16, 2006 07:27 PM
sonofsam
Nov 7, 2005 08:26 AM
puregroove
Apr 23, 2005 06:29 PM
jdstoledo
Apr 14, 2002 02:40 PM
