*Official H/T OFFROAD/LIFTED CR-V thread!*
Old Jan 11, 2018 | 12:35 PM
  #2676
Occidentalis's Avatar
Default Re: *Official H/T OFFROAD/LIFTED CR-V thread!*
Originally Posted by kokopelli
Awesome! Can you give me the short list on your lift and wheel/tires? ...I have an '05 that I have had for 3 years, and I know the complete history on (was a 1-owner), but I really keep wanting another Element...Or I want to lift the CRV....????
Try the performance thread or searching the forum. Your vehicle will have a completely different list than a 1st gen.
Old Jan 12, 2018 | 07:24 AM
  #2677
d-cheeze's Avatar
Originally Posted by ClabbeB
Finally got my 3" side steps from US.
Looking good !
Old Jan 14, 2018 | 08:55 AM
  #2678
ClabbeB's Avatar
Thx to Occidentalis, I spent the day pulling cables behind the window seal for the roof basket lights..
Old Jan 14, 2018 | 11:24 PM
  #2679
Fmmp's Avatar
Hello guys,
Anyone have MPC lower arms in lifted CRV 1st gen?
Thanks
Old Jan 15, 2018 | 11:10 AM
  #2680
asilversurfer1's Avatar
Originally Posted by JayTypeSH
Finally got my lift in!
Above picture was back in May of 2017 with no lift at all. Bottom picture is my V today with my lift: Tema4x4 30mm spacers all around, KYB shocks all around, OME springs in the rear
My CR-V is 2006 EX-AWD
Old Jan 15, 2018 | 11:18 AM
  #2681
Any rubbing?
Old Jan 15, 2018 | 08:02 PM
  #2682
JayTypeSH's Avatar
Originally Posted by asilversurfer1
Any rubbing?
The rear no longer rubs on bumps now. Before, with just the OME springs... it would still rub on large bumps or on dips when going fast. Also, the front doesn't rub on the fender anymore when turning into a ramp like it used to. It still rubs on turns though, but thats more the tire rubbing against the body more so than the top of the tire rubbing the fender. I've trimmed the bumper and some plastic pieces and its helped a lot. A little more trimming and I shouldn't have any more problems with rubbing... or at least I hope (fingers crossed).
Old Jan 16, 2018 | 08:08 AM
  #2683
Thanks for the quick reply. I was thinking that the weld pinches in the wheel wells would give you trouble? Your top photo looks aggressive. I'm using 225/70/15 tires and luv them! Very meaty! What is the offset of your wheels? I will be looking for some lighter rims and better tires soon!
Old Jan 19, 2018 | 01:11 AM
  #2684
ClabbeB's Avatar
And God said, “Let there be light,” and there was light. God saw that the light was good, and he separated the light from the darkness..
Old Jan 21, 2018 | 08:05 PM
  #2685
JayTypeSH's Avatar
Yeah, before the lift it would rub a lot. In the top photo, I had to put my wheels and tires on because I had a flat on my stock wheels. So suspension was completely stock in that top photo and my car would rub all the time on every turn and every bump, and I only drove it locally from home to work nearby until I got my rear OME springs. With just the rear OME springs, the ride got much better but would still rub on hard bumps and turns so I then got the 30mm spacers all around. Much better now, just have to do a bit more trimming to the front bumper then I should have zero rubbing from now on.
The offset of my wheels is 0. I also use 9mm wheel spacers to clear the calipers.
Old Jan 26, 2018 | 12:10 PM
  #2686
Thanks Jay!
Old Jan 29, 2018 | 01:13 PM
  #2687
thelazymechanic's Avatar
Question all!! Has anyone had any alignment issues after they have lifted their CRV? I seem to be having a bit of a toe issue that keeps coming back. Front end is tight (ball joints, tie rods, wheel bearings, control arms)
(GEN 2, 2004, CR-V 2.4 AWD)
Old Jan 30, 2018 | 02:30 AM
  #2688
Dansanders55's Avatar
Yeah, you should always get an alignment after a lift. You wanna make sure those big expense tires last as long as they can. Also any good shop will check all your ball joints, control arms, tie rods etc.
Old Jan 30, 2018 | 07:00 AM
  #2689
KINgJ8's Avatar
https://www.freeasestudyguides.com/memory-steer.html
Maybe memory steer is the issue in the older steering rack or the strut mount bushing were installed in the wrong orientation..hopefully not! GL
Old Jan 30, 2018 | 12:33 PM
  #2690
ClabbeB's Avatar
Front camber bolts and rear control arms solves that issue.. Mine is lifted 30mm (gen2 2006) and alignment is according to oem spec with above installed
Old Jan 31, 2018 | 12:57 PM
  #2691
I did get an alignment after i lifted it, (I wouldnt dare lift something without aligning it afterwards lol). Ithe alignment was performed and everything was in spec after the alignment, i put in adjustable control arms, camber bolts (in both upper and lower bolt holes in the strut) and with everything done i was at factory spec.ClabbeB did you notice a significant drop in fuel economy as well? I was expecting a drop but not almost half. I have it booked in for another alignment next week to see the specs (maybe the shop didnt align it properly). I usually do all my own stuff but i no longer work in a shop. The memory steer could be a possibility hmmmm......
Old Feb 1, 2018 | 01:29 AM
  #2692
ClabbeB's Avatar
ClabbeB did you notice a significant drop in fuel economy as well? .
A drop is always expected as you **** up the CW value when you raise a car.
However it shouldn´t be significant in my opinion.
Old Feb 6, 2018 | 03:48 AM
  #2693
ClabbeB's Avatar
Does any one have the installation instructions for the OEM cargo grid?
I can't wrap my head around it
Old Feb 6, 2018 | 06:09 PM
  #2694
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
I have never seen that option! That's sick!
Old Feb 7, 2018 | 06:46 AM
  #2695
ClabbeB's Avatar
Fnally managed to figure it out. Took 10 minutes to install.
Better security for my dog and my daughter..
Old Feb 7, 2018 | 03:39 PM
  #2696
KINgJ8's Avatar
Drooling over this not available to US accessory, that is cool and stout compared to the aftermarket ones i have used.
Old Feb 7, 2018 | 06:34 PM
  #2697
AndrewDB1's Avatar
I really like that as well, carry heavy stuff in the back all the time and would want it to stay back there in an accident!
Old Feb 7, 2018 | 07:03 PM
  #2698
ClabbeB's Avatar
Interesting that it was not available on the US market. Here you can pick them up second hand for around 80-100 USD
Old Feb 7, 2018 | 08:06 PM
  #2699
Caoboy's Avatar
-Intl Steve Krew
Loved
Yeah but how much is shipping from Bulgaria to the USA?
Old Feb 7, 2018 | 08:21 PM
  #2700
ClabbeB's Avatar
Probably more than you would be willing to pay :D
My 130USD side bars from Carid ended up at 380USD once landed in Bulgaria
