PCV breather box removal / BWR installed
Old Aug 17, 2017 | 09:39 PM
lolv8s's Avatar
10 Year Member
Default PCV breather box removal / BWR installed
B18a1 I removed my breather box and PCV valve and installed the BWR catch can. And I have this open ended pipe that plugs into the breather box/ PCV valve leftover that I circled in red. It's just gasses that come from the block. Would I be safe to run one of these mini air filters?
Old Aug 20, 2017 | 03:17 AM
lolv8s's Avatar
10 Year Member
Default Re: PCV breather box removal / BWR installed
bump
Old Aug 20, 2017 | 07:06 AM
v4lu3s's Avatar
RTFM
if you are wanting to keep the outside of your engine covered in a nice thin layer of oil mist those work well.
Old Aug 20, 2017 | 06:44 PM
lolv8s's Avatar
10 Year Member
would it be best just to remove that piece I circled in red and insert a bolt and plug it completely? Feels like you're condescending me haha that's why I asked the question. I wasn't sure. It's where the PCV valve plugs onto but I ran a BWR catch can that eliminates the OEM PCV valve and leaves that piece I circled in red open and unplugged.
Old Aug 20, 2017 | 09:23 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Yes, it is better to remove the hose barb you have circled in the pic you posted and replace it with a pipe plug.
Old Aug 22, 2017 | 03:56 AM
lolv8s's Avatar
10 Year Member
hose barb was the word I was looking for. But thanks for letting me know man!!
Old Aug 25, 2017 | 05:00 AM
lolv8s's Avatar
10 Year Member
got a brass piping plug and a little Hondabond and it's sealed.
Old Aug 29, 2017 | 07:43 PM
R35fanboi's Avatar
hoepfully you have some way to vent the crank case preasure elsewhere in your build.
Old Aug 30, 2017 | 12:08 PM
lolv8s's Avatar
10 Year Member
it's ventilated to my BWR catch can/box
Old Sep 29, 2017 | 12:55 AM
KillerDragn's Avatar
How the hell did you get your block plug in? Ive tried freezing mine, sanding down the o-rings, lubing it up, and obviously the combination of all three. Im about to return it.. It just wont slide in past the first o-ring, I feel like I exert any more force on it im gonna nudge the car off the jackstands lmao.
Old Sep 30, 2017 | 08:17 AM
lolv8s's Avatar
10 Year Member
mine slid in just fine. You have the hole wide open right nothing blocking? And where did you buy the catch can? Directly from BWR? Or is it a mock BWR? In that case it’s possible it wasn’t machined correctly or made too big.
Rick1t
Jan 7, 2016 11:58 AM
igorka_91
Welding / Fabrication
91
Apr 16, 2013 09:31 PM
mr_gs-r
Dec 7, 2007 10:04 PM
ToeJam
Mar 31, 2007 12:15 AM
90laser_rst
Sep 9, 2006 07:08 PM
