Urgent need of help popping noise coming from automatic Integra shifter
Old Jun 27, 2017 | 09:30 AM
89brokendownEF's Avatar
Default Urgent need of help popping noise coming from automatic Integra shifter
I have a 2001 Acura Integra GS automatic. I noticed today when shifting from Park to drive I heard a loud clunking noise coming from shifter area. I put car into reverse car makes popping noise when going into reverse. Also will make popping noise when engaging to drive. I changed all front end suspension the noise sounds like it's coming from the shift linkage or shifter area. If I put it in drive and give it gas to take off I hear a popping noise Upon take off. This is not coming from the front end I believe it has something to do with the shifter or shifter linkage. Hopefully someone on here in guide me in the right direction thank you
Old Jun 27, 2017 | 09:48 AM
Default Re: Urgent need of help popping noise coming from automatic Integra shifter
Anyone got any idea I don't want to pay honda 90$ diAgnose it
Old Jun 28, 2017 | 12:11 PM
bump i need to drive this car soon
Old Jun 29, 2017 | 02:35 AM
PHAT-INTEGRA's Avatar
Could be any of these symptoms any CEL?
Low transmission fluid level.
Failed Motor Mounts or trans mount.
CV Joints.
The more I think about it. Could be your axles and or half shaft.
Old Jun 29, 2017 | 04:22 AM
CV Joints.
​​​​​​​The noise seems like is coming from shifter area
Old Jun 29, 2017 | 06:52 AM
CandyRedRC46's Avatar
Well even though its sounds like its coming from the shifter, why don't you do those trying to help you diagnose over the internet a favor.
Check your fluid(s)
Check your mounts (all 5)
Check you axles/cv boots
Check your shifter linkage
Then get back to us.
Old Jun 29, 2017 | 07:29 AM
tony_2018's Avatar
Fish Twig
A video would help.
Old Jun 30, 2017 | 02:34 AM
Check your fluid.
Shifter linkage? You mean shaft control...
He has a Hydraulic Automatic transmission.
Old Jun 30, 2017 | 08:02 AM
​​​​​​​ I just somewhat redid the exhaust and put a new donut gasket in between the cat. My engine does move quite a bit when going from reverse to drive. It is hard for me to isolate the sound of the noise. I am thinking the spring kit between the cat could be causing noise. I have been having issues where the shifter is hard to get in and out of park. I'm not sure what to do I am thinking about buying all new mounts. I don't want to be throwing a bunch of money at it.
Old Jun 30, 2017 | 10:54 AM
tony_2018's Avatar
Fish Twig
So maybe check your engine mounts?
Old Jun 30, 2017 | 01:52 PM
i have been looking at mounts online, i do not want to keep popping a bunch of money into this car. they sell a set of all 5 mounts on ebay for like $65 with shipping. do you think the ebay mounts will be anygood. rock auto mounts total at $75 plus shipping. the motor moves pretty good when moving between gears.
Old Jul 3, 2017 | 05:17 AM
No I mean the linkage, as in the linkage/cables etc that connect the shifter to the transmission. As in here in this link:
http://www.ebay.com/itm/1997-Integra...JRlUKc&vxp=mtr
Have you ever worked on an automatic Integra before?
Old Jul 3, 2017 | 05:21 AM
C A N Y O U C H E C K Y O U R M O U N T S A L R E A D Y ? ? ?
Old Jul 3, 2017 | 05:23 AM
Sounds like your mounts are bad.
Check your mounts.
​​​​​​​Check your mounts.
Check your mounts.
​​​​​​​Sounds like your mounts are bad.
Check your mounts.
Check your mounts.
Check your mounts.
Check your mounts.
Check your mounts.
Check your mounts.
Old Jul 4, 2017 | 04:12 AM
[QUOTE=CandyRedRC46;51335497]
​​​​​​​If you would have read that I stated I was buying new mounts, you just try to start problems.
Old Jul 4, 2017 | 04:55 AM
tony_2018's Avatar
Fish Twig
Uh, no. He's not. You just have a hard time reading what has been stated, or what members have advised you should do.
Old Jul 4, 2017 | 04:59 AM
tony_2018's Avatar
Fish Twig
Check your fluid.
1997 Integra LS 4 door automatic shifter cable linkage shift | eBay
I think this is where the confusion was, just call it the automatic shift cable. When you say shift linkage we're all thinking the 5spd shift linkage.
Old Jul 6, 2017 | 01:55 AM
Yes I have and it's been over 7 years since I dropped an Automatic transmission. When you said shifter linkage. I'm thinking manual transmission.
There is a procedure to check your mounts. By holding down the brakes and rev the motor while in drive and reverse while the hood is open to see if the motor twisted or jump and from there you know witch mounts are bad. You can google it there should be videos floating around on youtube, etc.
Old Jul 6, 2017 | 07:55 AM
W A S
T H I N K I N G
A N D
L O O K I N G
Old Jul 6, 2017 | 08:21 AM
W A S
T H I N K I N G
A N D
​​​​​​​L O O K I N G
​​​​​​​ I ordered all new mounts for the car. A sixteen-year-old car, do not need to check the motor mounts as I said motor move quite a bit. Obviously there is a problem sorry I upset you by not getting back to you right away I work two jobs. Thank,you
Old Jul 6, 2017 | 08:25 AM
Thank you all for help, I will provide update after installation of all new mounts I also have new exhaust system to go on. Thank you all I'm sure it was due to the mounts in the donut gasket flexing. We will find out after replacing all mounts.
Old Jul 6, 2017 | 08:57 AM
if yOu WouLd HAve rEAd tHaT i StAted i WaS tRyiNg tO teLL YOu To cHECk yOUr cuRrenT MOunTs, bEFoRe bUyInG NEw MOunTs, yOu JUst TRy tO sTaRt pROblEms.
Old Jul 6, 2017 | 10:44 PM
​​​​​​​You suck
tilhasbb
15
Jun 3, 2008 05:40 AM
ITR#JohnBasedow
Feb 10, 2003 01:39 PM
