H22 swap won't start
Old May 22, 2017 | 01:07 PM
Jianshatch's Avatar
Default H22 swap won't start
I searched and tried everything I could think of sleeved and built h22 swapped into civic eg where a f20b was so wiring is the same. It has spark don't ask me how I know it gets fuel checked fuel pump main relay and rail I used some starter fluid and cranked it , the tb caught fire I think it's the dizzy or my timing which could be a hair off . Please input i put ground to tranny and therm and valve cover. Stock injectors and ecu and tb boost pipes aren't connected
Old May 22, 2017 | 04:43 PM
Jianshatch's Avatar
Default Re: H22 swap won't start
Preview owner removed cel lol so I replaced bulb and when I jump diagnostic cel stays on what could it be I fried the ecu from not having a ground
Old May 23, 2017 | 12:36 PM
Jianshatch's Avatar
Any help from some Honda gurus I get code 41 now which is o2 sensor I went over the grounds I do have spark plugs in that are like 5 step colder for the turbo maybe they're gapped to tight
Old May 25, 2017 | 05:11 AM
Jianshatch's Avatar
pulls the plugs out and replaced them with old plugs motor turning over took valve cover off and exhaust timing is advanced one degree would that cause it to not start
Old May 26, 2017 | 06:58 AM
civic-steve-94's Avatar
If you have spark and fuel and know the injectors are pulsing, then do mechanical checks. Set the timing where it is supposed to be , check valve lash, do a compression and leak down check. Whats been done to the engine?
Old May 26, 2017 | 07:15 AM
Jianshatch's Avatar
eagle rods cp pistons new bearings I think it's timing exhaust is off by a tooth or two advanced couldn't get the cam to stay still when I was bolting it down. And valves got springs and retained so valve lash may be a problem too
Old May 29, 2017 | 05:21 PM
Jianshatch's Avatar
mechanical timing re done exhaust was off but now it's good and checked tdc like 10 times I can't get it to start
Old May 30, 2017 | 02:54 PM
Jianshatch's Avatar
Any help I really could use some , it was a civic harness converted to f/h by last owner , how do u make sure dizzy timing is good
Old May 30, 2017 | 09:19 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Have you tried to clean your spark plugs after multiple attempts to start the car while out of mechanical time ??? Sometimes it is that simple.
Old May 31, 2017 | 03:03 PM
Jianshatch's Avatar
i swapped the new plugs to some older ones I had working before I pulled the motor out, I'll willing to pay someone to fix it in the DMV area now
Old Jun 7, 2017 | 03:41 PM
Jianshatch's Avatar
over a week and can't get it to start and ideas really need Honda techs help
Old Mar 18, 2018 | 08:35 AM
griggc's Avatar
Did this issue get resolved?
Old Apr 16, 2018 | 04:56 PM
Jerk1cn's Avatar
bump
cjm81
Nov 16, 2013 08:42 AM
redline7
Jul 16, 2007 08:49 AM
hotrodaccord
Jul 10, 2006 06:59 PM
