Wrenching Your EF
Old Mar 27, 2017 | 03:17 PM
  #551
.Manny.'s Avatar
Touching My Member
Default Re: Wrenching Your EF
Old Mar 27, 2017 | 06:05 PM
  #552
crookson speed's Avatar
welded in a length of 1.5x1.5 square tubing under the front fender in the corner and it makes a huge difference in feel. so much mechanical grip with the addition of a etd k tuned traction bar the front end no longer sags down whe. you let go of the jack
Old Mar 28, 2017 | 07:43 AM
  #553
AZCRXSI's Avatar
10 Year Member
Originally Posted by .Manny.
Nice! Glad you made it to the track. What did you learn about the car or what adjustments do you want to make? What did you learn going around the track as a driver?
Very cool!
Old Mar 28, 2017 | 08:58 AM
  #554
ssmrico's Avatar
Old Mar 29, 2017 | 03:53 AM
  #555
dylspil's Avatar
Old Mar 29, 2017 | 07:11 AM
  #556
.Manny.'s Avatar
Touching My Member
Very cool!
No adjustments at all yet. The car was aligned and corner balanced beautifully by Chewerks. I just need a ton of seat time before my skills surpass the current set up, to be honest. I ran in the novice group and glad I did. Learned all the Do's and Don't's of being on track, flags, etiquette, etc. I'm going to do my best to run all 9 HFF Challenge events and class up by the third event. I'll post more as I go along.
Originally Posted by ssmrico
whatchu dooooooin?
Originally Posted by dylspil
looking real good.
Old Mar 29, 2017 | 07:17 AM
  #557
ssmrico's Avatar
whatchu dooooooin?
looking real good.
new forward facing turbo kit, hood lashes, coolant reservoir, new radiator, type r oil pump, gates racing timing belt, booster delete, hondata cop kit, new wg, full hydro conversion for clutch etc, hardrace lower control arms, s300 v3 update, skunk stage 2 tuner cams, head gasket, new titanium valve train, rear diffuser, possibly a new sleeved block since mine is built but block guard only so if I can sell it ill get sleeved one,
still need to order the ks tuned front brakes for it and twin clutch,
I think that's all on the list right now
Old May 6, 2017 | 06:47 PM
  #558
KadenEF's Avatar
Got this set of bmw bottlecaps for $50!
Old May 8, 2017 | 05:24 AM
  #559
ssmrico's Avatar
Old May 10, 2017 | 07:43 AM
  #560
BattleGround's Avatar
The past 5 days I changed the head, and put on coilovers and suspension pieces and new wheels. Today I'm rolling the fenders slightly and adjusting the valves
Old May 10, 2017 | 07:59 AM
  #561
BETaEF's Avatar
what coil overs you go with? Any pics would be appreciated!
Old May 10, 2017 | 09:14 AM
  #562
ikem's Avatar
Starting my long term project.
91 CRX Si, B16a. I have had it for .. 10 years now, but finally in a place to start restoring it. Working on the chassis and body first, then working on the powerplant. Hoping to boost.
Ordered the replacement panels and gutted interior so far. Salvage title when I bought it, front end deer. So i need the frame pulled back out a bit
Old May 10, 2017 | 01:25 PM
  #563
I have Yonaka basic coilovers because I got them used with a ton of other parts. The spring rates are 12/6 (roughly 675/325) and the front is just way too stiff so I ordered a pair of 450lb front springs to change them out. I wouldn't buy them new, but they are surprisingly decent to drive on. Not painful and greatly reduced body roll. I really think they need an 8/6 rate not a 12/6 rate though
I decided not to use the skunk2 upper control arms because my stock arms are in great shape.
Old Sep 28, 2017 | 11:53 AM
  #564
AZCRXSI's Avatar
10 Year Member
Took him to work today and hit 250,000 miles on the odometer...
Not too bad.
Old Sep 29, 2017 | 01:53 PM
  #565
.Manny.'s Avatar
Touching My Member
Ditched the Speedfactory tucked Radiator and went back to my old Fluidyne full size rad. Did not like dealing with BS overheating issues.
Also, had some used Hoosier SM7 tires mounted in preparation for some events at the end of the year.
Old Oct 2, 2017 | 04:26 AM
  #566
ssmrico's Avatar
looks good. pic of old rad?
Old Oct 2, 2017 | 09:41 AM
  #567
.Manny.'s Avatar
Touching My Member
Wanna buy it? Good for Drag setup, not so much for road racing.
Old Oct 5, 2017 | 11:48 PM
  #568
crx_si-r's Avatar
clear ef8 bumper lights
ef s2k push start switch and plate
LHD CARBON FIBER POWER WINDOW SWITCHES
got some goodies for my EE8 inspired project
Old Oct 6, 2017 | 04:42 AM
  #569
ssmrico's Avatar
man looks good but wont work with my new FF set up
Old Oct 8, 2017 | 01:51 PM
  #570
smilindave's Avatar
Hey all,
Just a reminder, when swapping alternators on an ef with a d series.Remove the oil filter and remove top fasteners on left front shock to allow the alternator to come out from the bottom. My 55 year old brain forgot the shock drop to allow clearance with the half shaft. After about an hour fiddle farting around, I remembered.
Regards
Dave
Old Oct 8, 2017 | 03:03 PM
  #571
DaX's Avatar
DaX
Loved
Community Favorite
New lock cores in the doors, trunk, and ignition.
New climate control, as the slider that selects where the air comes out has not worked for about 18 months.
Installed the bracket that supports the front of the center console, in front of the gear shifter (I never put it back in when I did my auto-to-manual swap about 10 years ago).
408,000 miles and still rolling.
Old Oct 16, 2017 | 11:15 PM
  #572
WestyNaut92's Avatar
Well, major change today, got a set of VW P-Slots with tires on the hatch today!
Also got a PM5 ecu (have to do an idle relearn on it), a new dome light off a wagon (also where my ECU came from) and what look like decent condition DPFI injectors.
Tomorrow we will strip out the plastics in the rear interior and maybe swap out some injectors
Old Oct 30, 2017 | 09:21 PM
  #573
AZCRXSI's Avatar
10 Year Member
New Civics need to be put on a diet...
Old Nov 6, 2017 | 05:40 AM
  #574
sstupid's Avatar
10 Year Member
Yesterday on my 1988 Civic hatch DX, 213000 miles:
1). Installed new steering rack, inner tie rods, and outer tie rods.
2). Installed new compressor, dryer, condenser, sucked down, and recharged with R134. Have 40 degree center vent temps with 90 degree ambient.
3(. Installed new hood pull cable. The one on Amazon is a great product. Could not tell difference from OEM. Did not come with the plastic holder clips though.
Old Nov 11, 2017 | 03:15 PM
  #575
DaX's Avatar
DaX
Loved
Community Favorite
Working on making an MPFI harness
