Re: My build thread-1991 usdm honda crx si d16a6 sohc zc all motor N/A
you see that lil bevel right there?
What is it for?
I think it suppose to prevent back flow of aair, like this
By creating little venturis that keep the flow of air in that direction Untitled by (ai), on Flickr
But the skuunk2 and others dont follow it
see.
Anyway my inlet is gonna probaly look like this
tapered
d-you just skip everything?
d16a6 Throttle bodies only work with d16a6, d16a1, 1988-1989 sohc and dohc zc manifolds
1986-1987 accord, integra and preludes as well. except the tps on these is different. But they can be switched out for the newer version
Basically, they're all the same, a "GF" stamp on top.
A d15b7 manifold looks very similar to a d16a6 and accepts b series throttle bodies but idunno if the manifold support bracket lines up.
I figured out what that lip is for. GM and chrysler throttle bodies have it, it's just to seal the butterfly.
general mass produced castings, too expensive to go in and smooth out that lip on a throttle body over a superficial gain.
So I'll blend it in as planned.
Sill cant find an oe throttle body though
This is what I decided to do. A bigger throttle body increases volume, but on a stock NA engine with no aggressive need or ability to pull in larger amounts of air. You lose velocity and that means low end torque and HP because it wont be pulling larger amounts of air until at speed.
So, I know my Manifold is ~ 56 mm and the throttle body is ~56 mm at the rear. And this was the best option for me.(Because I didnt want to have my manifold port matched to a straight through 59 mm TB
I made my opening to 59 mm and tapered it so it transitions smoothly to the oe spec.
This creates a venturi effect which increases air velocity. Which means at low speed you'll get more air because the design will help push air in faster. Perfect for a stock spec engine.
I also made a TB spacer simply by making another thermal gasket out of cutting board, I had to back out the oe studs to get it to bolt on however. This creates a thermal barrier and also increases plenum volume. Which I believe means there is just more air available and less chance for cylinders to be starved of oxygen.
I got to start it and there is a noticeable change in sound, but who knows if this means a gain.
I won't get to see until tommorrow.
You can't tell from the photos, but the TB has a slight bevel, like a velocity stack
_MG_9836 by (ai), on Flickr
Then I removed the tape and put coton ball in the iacv hole and taped closer to the butter fly and hit it with 600 grit to get an even smoother transition to the center. which is ~ 56 mm
Put my TB spacer on as well, had to back out the oe studs to get it to bolt on though/
Good thread.
Have you ever thought of finding a spare D16A6 with lots of miles, and building it N/A using Honda parts? I built an 11:1CR D16A6 using 1989 Integra D16A1 "P29" pistons, and a metal OEM head gasket from the 96-98 D16Y8. That set-up combined with an Si/ZC hybrid tranny walked B16A swaps all day, got good gas mileage, and ran forever on premium fuel. It wasn't an expensive build either.
Spending time and effort on the little things like plugs, wires, TB, etc. are great, but in the end they have a very small impact on how much power you'll put down. You're capable of this build, I'm sure, and it was a ton of fun to drive it when it wad done.
Originally Posted by Caoboy
Why did you loop that coolant line?
Is it just an out<-in line?
Yea, coolant passes through the TB from the head, to the iacv and back to the block from the iacv.
I have all that bypassed from the block to the head, and I just popped that line on there to keep bugs out.
Keepst he manifold and TB cooler
Originally Posted by 91crxsipokeball
I did the accord swap to my climate control it was cracked in every which way possible lol only took about 3 hours to connect the wires and mixer
Isn't the accord one vacuum controlled? My temp **** is still racked at the rear_ the part that moves the mixer) And only the crx 's use the same one.
Originally Posted by B18C5-EH2
Good thread.
Hey guys, for the longest time the portion of my rear cargo cover that folds down. Had a clip broken. Today I was able to make a new piece.
I can make more if anyone's interested in buying one.
I am also going to make a rear view mirror cover because mine is broken
Last photo is blurry but it worked out very well. They are the same size, only my original is bowed out so it looks shorter
3d printed one
oe one
broken one
mirror cover concept
" target="_blank">
This oil cap I will be making. Has a provision so you can insert a gasket from your old oil cap
Alright guys, took my mirror off to get good measurements.
And designed this and it's currently printing.
" target="_blank">
Also, I noticed how the mirror is attached to the stem and since I use a broadway mirror. I designed this piece to replace the rearview. It's lighter slimmer and hollow too so you can have a lil hidden pocket.
I don;t think I will have enough material left to print it though, but as soon as I get some I'll give it a try.
good news and bad, cover was coming along nice but ran out of filament around 87 percent done.
Fuu, I covered the gap with electric tape and it's on with double tape.
It's also a lil thick, the original is probably 2 mm thick and mine I designed slightly thicker for strength.
" target="_blank">
Oil cap came out nice.
It's much smaller than any other oil cap, that really stick out like a sore thumb on our small engines.
Has much less overhang.
Guys update.
I installed innovative steel 75a mounts
vibration was crazy at first still pretty harsh. These have two problems that need to be resolved.
1. you need a spacer on the driver side mount for the stud bolt because the innovative mount is thinner than oe. and the threads on that stud do not go down enough.
2. on the passenger side mount you need another spacer, this one for the bolt that goes through the bushing. The steel insert that they use is about 3 mm too narrow, it will pinch the bushing and cause it to bind. Causing VERY bad vibrations
Get a washer and dremel it to fit, slip it in the side closest the firewall.
3.* This one might apply only to me because I have an odd front torque mount setup. The innovative mounts were causing my front mount to bind I believe. I removed it, I'm only running the two side innovative mounts and the rear oe. mount.
I am unsure if I will install the rear innovative torque mount.
Aaaaand, I designed this for the 91 si crx to fit in the bumpers fake ducts.
I have my cold air filter located there and I believe a simple velocity stack like this could add maybe .2 hp
My 3d printer cant accomodate it but I might be able to split it and print it in two sections then glue them together post.
It's just a rough sketch not an exact fit.
Here's where you need a spacer, I used a large nut, if you can you can cut out the round spacer from your oe mount.
I couldn't after trying for about 20 minutes.
More filament arrived today. So I printed the other 20 percent of the piece, glued 'em together.
Need quite a bit of post still to get it to fit. Mine was too long, ad that angle of that arc was wrong on mine.
I got it darn close and am happy with it.
