gutted-dx's Sleeved B16 STC Surfer Engine Build Progress Thread.
Old Oct 18, 2016 | 03:46 PM
  #201
boosted94gsr's Avatar
Default re: gutted-dx's Sleeved B16 STC Surfer Engine Build Progress Thread.
From what I can see from the pic your plugs look pretty good. Looks like if anything a little rich at wot, but hard to tell from the pic. Do you have a wideband? If so what are your afrs like at wot?
Old Oct 18, 2016 | 06:08 PM
  #202
gutted-dx's Avatar
10- 10.5. Shouldn't it be 12.5 or so ?
Old Oct 18, 2016 | 06:51 PM
  #203
Wow that's waaaay too rich. Should be ~11.5 and that's still conservative. I'm very surprised English would tune it that rich. Maybe post your maps. Low cam and high cam ignition and 2d fuel maps make sure you include the boost columns.
Old Oct 19, 2016 | 09:59 AM
  #204
gutted-dx's Avatar
Old Oct 19, 2016 | 10:03 AM
  #205
gutted-dx's Avatar
Old Oct 19, 2016 | 10:05 AM
  #206
gutted-dx's Avatar
It still gets good gas mileage and doesn't smell like its running rich either. I also fixed a boost leak that it had when it was tuned.
Old Oct 19, 2016 | 10:48 AM
  #207
Do you know if it's in closed loop? If it is it will correct your part throttle afrs to ~14.7 and you will get good gas mileage. Your low cam fuel map looks pretty choppy to me, but it's the 10-10.5 afr at wot that worries me. Did it run that rich before you fixed the boost leak? If the boost leak was bad enough it might need a clean up tune. Can you post the high and low cam ignition tables too, make sure you show the boost columns up to at least 16psi. It was tuned at 16psi right?
Old Oct 19, 2016 | 11:13 AM
  #208
mrdrpep's Avatar
A boost leak would cause a richer af, correct? Because you're not pumping in as much of the intended air, it would run richer. I noticed a change in my a/f when I changed my intercooler piping/plumping (probably due to a leak I had or too much restriction in the bends,etc... Also, I'm ignoring my o2 sensor (open loop) for now until I get it as close as I want it.
Old Oct 19, 2016 | 11:36 AM
  #209
gutted-dx's Avatar
I never noticed it before but i also wasnt paying much attention. Haha to be honest i have no clue how to show the boost columns. It was tuned to 15psi. i have a pic of the dyno graph also and it to is choppy. I'll get the ignition up in a second. Could this have anything to do with running old gas in the car while being tuned?
Old Oct 19, 2016 | 11:51 AM
  #210
You have to select "show 3 bar map" in the settings. Getting it tuned on old gas definitely is not a good thing.
Old Oct 19, 2016 | 11:58 AM
  #211
Not necessarily. Speed density based efi uses the map sensor, iat, and tps to determine fueling. A leak before the throttle body won't really affect that, it will make your turbo work harder and spool slower. If the boost leak was bad enough that you are now hitting an untuned part of the map after fixing a boost leak, then yes afrs could be affected.
Old Oct 19, 2016 | 02:40 PM
  #212
2kdrift's Avatar
hmm way to choppy for my liking (im not a tuner at all)
in my experience those spiked areas your engine may have not seen at the dyno, but when you get on the street and you hit those spots your afrs will be off
Old Oct 19, 2016 | 03:20 PM
  #213
gutted-dx's Avatar
2k, that's also what I was thinking (also not a tuner). From what I've read its supposed to be smooth and linear. The ignition table looks about the same, choppy.
On a side note the slim fan was to big so, I ordered a 12in spal. A 13in was nowhere near fitting.
Joe
  #214
gutted-dx's Avatar
Joe
Old Oct 19, 2016 | 03:38 PM
  #215
2kdrift's Avatar
haha yep 12" is the one that worked for me also.
yea My first tune was very choppy like yours actually it was worse then yours I had lean spots in boost since the turbo was spooling faster on the street then at the dyno, new tuner seems to know what hes doing (not saying anything good or bad about english I know nothing about them)
this is what mine look like now
Old Oct 19, 2016 | 06:44 PM
  #216
gutted-dx's Avatar
What caused it to spool faster on the street? As soon as I sell the damn top mount I bought for no damn reason.
Old Oct 20, 2016 | 06:14 AM
  #217
Sometimes the actual road is better at loading up the engine. Same reason you produced boost at a lower rpm in 4th gear vs 1st.
2k's tune is more what you'd expect to see from a tune done right. At 2k you posted your high cam fuel map twice instead of your high cam ignition map FYI. Looks good though man.
Old Oct 20, 2016 | 06:50 AM
  #218
LightningTeg's Avatar
Community Builder
I could have sworn I posted like this exact message earlier.. hmm lol.
Yeah load on the street is always different then dyno load. Tunes should be verified with street driving prior to being called "complete"
Old Oct 20, 2016 | 04:10 PM
  #219
gutted-dx's Avatar
I have the wideband set up for d10 (eld) if I remember right, the wideband is also grounded on the tstat. What's the best way to calibrate the gauage to the laptop? Just hold them next to each and **** with the offset or is it never gonna be dead on? Gonna do a little remote tuning so I wanna get the reading possible.
Joe
Old Oct 20, 2016 | 05:25 PM
  #220
gutted-dx's Avatar
Here's the finished dyno.
Old Oct 20, 2016 | 05:58 PM
  #221
Joe
The best way I have found is to make sure you have a stable afr like after it warms up, then adjust the wb offset until the gauge and laptop match. Typical you will have variations between the two at different wb voltages, so what you need to do is create more break points in the wb voltage/afr scaling. To do this adjust the overall fuel trim to change you afr until you get a steady afr (i.e. 14:1) on the gauge, take note of the eld voltage, and add that break point to the scaling. Then continue to do this for 13,12,11 afr until you have it reading accurately between the two for every 1 point change in afr. You might need more breakpoints or you might need less, just depends on your specific car. So you might end up with something like this 0v=10.00afr,1.2v=11.9afr, 2.1v=14.2afr and so on until you have the whole scale from 0-5 volts. Also remember to put your overall fuel trim back to what your tuner set it to when your done with the scaling.
Hope that helps and makes sense lol.
Old Oct 20, 2016 | 06:27 PM
  #222
gutted-dx's Avatar
Yeah I kinda know what you're talking about. The wb came with a list of Cal numbers but it looks like I'll have to fine tune it.
Old Oct 20, 2016 | 06:28 PM
  #223
2kdrift's Avatar
what is the manufacturer of you wideband?
I just used the voltage specs that were in the manual, once I updated the voltages I just double checked that laptop and gauge were showing the same
my offset is set to 0
Old Oct 20, 2016 | 06:39 PM
  #224
Yeah it's nice when you can just input the manufacturers voltage scale and be done with it, but most of the time they need to be fine tuned.
Old Oct 20, 2016 | 06:41 PM
  #225
2kdrift's Avatar
Hmm I see I would think that the gauge itself also has the same numbers pre programmed into it. It just changes the display based on voltage, if all your connections are good I dont see why you would need to fine tune it much
