Titan101's GSR 2.0L Interceptor / Terminator Build Expansion
Old Jul 25, 2016 | 08:49 AM
  #226
TheShodan's Avatar
Moderator
Default re: Titan101's GSR 2.0L Interceptor / Terminator Build Expansion
Originally Posted by titan101
Time to get radiator checked
You mean switched. From my experience, those GAW Radiators really couldn't handle 400-600whp punishment. Usually construction, and use of its slim fan, but . Other's can chime in with individual experiences with that radiator, but from what I've experienced with it through many others, they always needed to be switched out when getting the power up. System is only good as it's weakest link..
Old Jul 29, 2016 | 10:55 AM
  #227
titan101's Avatar
Just found out I have been running without vtec since I built the engine. I was cleaning my vtec solenoid and noticed the plug I used in place of the pressure switch was holding the piston inside in place. Tuner says I need to get back on the rollers lol. I could never hear it and always thought I wouldnt notice it.
Old Jul 29, 2016 | 11:06 AM
  #228
LightningTeg's Avatar
Community Builder
Primary lobe is big enough to make 630whp without vtec?. I dont know how your tuner didnt notice either...
Old Jul 29, 2016 | 11:50 AM
  #229
2kdrift's Avatar
Seems very odd, Usually you get a CEL code lack of power would have to be noticeable as well. I can definitely notice a big difference audibly and otherwise when my VTEC engages
Old Jul 30, 2016 | 05:32 AM
  #230
titan101's Avatar
Makes plenty of power and I doubt I would be able to hear it once the waste gate opens. But it definitely has been without vtec. I had the set screw tighten really tight into the piston and it was locked.
Old Jul 31, 2016 | 06:13 AM
  #231
titan101's Avatar
1320 <3
Old Jul 31, 2016 | 09:41 AM
  #232
Community Builder
Streetcar takeover?
Old Jul 31, 2016 | 10:16 AM
  #233
titan101's Avatar
Yea I got paid in the fwd roll races
Old Jul 31, 2016 | 12:09 PM
  #234
justYncredible's Avatar
It's wU to the sOLdiEr!
will the video be on their youtube channel at some point in the future?
Old Jul 31, 2016 | 12:28 PM
  #235
Community Builder
So what was the verdict on the head gasket? My cars doing exact same thing, gasket looks exact same way as did cylinders. Just swapped in a new one in same issues =(
Old Aug 1, 2016 | 09:37 AM
  #236
titan101's Avatar
Im not sure I have seen a few videos of the drag racing from that day so far.
Old Aug 1, 2016 | 10:24 AM
  #237
titan101's Avatar
I changed to a GE head gasket from cometic and made sure I did my arp torque right. My tuner told me they run speedfactory L19 studs and JE gaskets on their cars over 30 psi. So next time around ill swap out. Also had a small low spot in head so had it milled. Ran it hard this weekend and my cooling system is finally stable.
Old Aug 1, 2016 | 10:27 AM
  #238
titan101's Avatar
Im excited for retune with vtec this week and rematch!
Old Aug 1, 2016 | 10:52 AM
  #239
titan101's Avatar
750 whp gt500
600+ hp h22 hatch
BWM 135i
brakes
Old Aug 2, 2016 | 02:37 AM
  #240
Community Builder
Good runs
Old Aug 4, 2016 | 04:36 PM
  #241
titan101's Avatar
Vtec!!!! 734! Lmao
Old Aug 5, 2016 | 04:15 AM
  #242
Community Builder
Thats more like it! lol.
Im still baffled how it was missed.
Old Aug 5, 2016 | 08:08 AM
  #243
Dark_Teg's Avatar
Whats A good way to test and make sure VTEC is working. When I was all motor I could hear VTEC kick in. My last turbo set-up I couldnt hear it at all. Considering I have to drive 5 1/2 hours one way for a tune I don't want any issues.
Old Aug 5, 2016 | 09:27 AM
  #244
TheShodan's Avatar
Moderator
Vtec!!!! 734! Lmao
On a T4 .63A/R 68mm GT turbine wheel no less.... And you are at over 4658 foot altitude, is that correct?. Very nice and interesting.
Old Aug 5, 2016 | 12:12 PM
  #245
titan101's Avatar
Yes 5280ft. It sounds completely different with vtec. Tuner said we could get 760 ish out of it if we cared about the number. Its a safe tune because I beat on it. He loves you shoden lol. You told turbo me I should max around 700 at my elevation and I was happy at 636. He already had the high and low maps set so we ran without vtec and got 600 (to make sure I wasn't full of ****) and then we plugged it in and the first run was 734 with 11.5 afrs. And we called it good lol. The cams are the magic lol.
Old Aug 5, 2016 | 12:36 PM
  #246
TheShodan's Avatar
Moderator
Old Aug 5, 2016 | 01:15 PM
  #247
2kdrift's Avatar
surprised he didnt do this sooner, to find proper VTEC point. see what I mean about being audible...perhaps not the same as an NA setup but its there. Congrats anyway glad you got it all figured out.
@Dark_Teg typically you would get a CEL if its not working, I use a vtec light LOL but I wouldn't actually recommend that and that just tells me that the ECU is sending a signal to the solenoid, but between that, the audible and power it makes after vtec engages
Old Aug 7, 2016 | 05:52 PM
  #248
ryguy2588's Avatar
Damn that turbo puts down some power! Just ordered my Reaper with the 74mm turbine wheel and T4 0.68 A/R housing. I'm in Idaho now, but Nayr will be tuning my car once it's put together. The guys at CoRaceFab are awesome.
Old Aug 7, 2016 | 08:17 PM
  #249
K20A3F00L's Avatar
Love the car, do you have a front lip for it, feels like it is lacking a lip. Extremely clean *** car doe!
Old Aug 8, 2016 | 11:10 AM
  #250
titan101's Avatar
I have the front and rear lip in my garage, they were painted when the car got its paint job just didn't add them yet.
