1991 Civic Si - Picture Collection
Old Mar 31, 2016 | 06:16 PM
  #26
kp's Avatar
kp
Default Re: 1991 Civic Si - Picture Collection
The motor and trans had a good amount of oily crud on them from a few different leaks.
The breakdown begins. Every nut and bolt will be bagged and labeled along the way.
Old Apr 3, 2016 | 03:58 PM
  #27
kp's Avatar
kp
Next up was the head disassembly and clean up. The head gasket was fused to the aluminum and took considerable effort to remove. The valves needed a good lapping as well. Valve seals, o-rings and seals also replaced along the way.
Old Apr 3, 2016 | 08:17 PM
  #28
Evo9GSR's Avatar
Just beautiful
Old Apr 3, 2016 | 09:17 PM
  #29
b20hatchek's Avatar
Old Apr 3, 2016 | 09:20 PM
  #30
.Grimace's Avatar
footwork mastery
I want to sell my CRX to find an 88-89 si hatchback to do this with. Well done
Old Apr 5, 2016 | 07:05 PM
  #31
kp's Avatar
kp
Moving right along. I disassembled the bottom end and thoroughly cleaned the block, pistons, oil pan etc. The ring lands were also cleaned in preparation for new rings.
Old Apr 5, 2016 | 08:15 PM
  #32
EE2bitsk's Avatar
awesome work. can't wait to see the motor back in the bay.
Old Apr 8, 2016 | 07:56 AM
  #33
kp's Avatar
kp
A small update, more cleaning.
Old Apr 8, 2016 | 11:53 AM
  #34
SupremeDalek209's Avatar
10 Year Member
fantastic work!
Old Apr 8, 2016 | 11:58 PM
  #35
b20hatchek's Avatar
Great work
Old Apr 9, 2016 | 03:16 PM
  #36
kp's Avatar
kp
The bottom end is assembled and torqued. Everything cleaned along the way.
Old Apr 10, 2016 | 04:28 AM
  #37
Bluto!'s Avatar
I'm glad the car fell into good hands. Keep up the great work.
Old Apr 10, 2016 | 06:47 AM
  #38
$amGD3's Avatar
Swaggylicious
Such a satisfying thread, more!!!
Old Apr 10, 2016 | 09:37 AM
  #39
kp's Avatar
kp
Thanks for the kind words guys.
The transmission received a new shift rod seal, and new axle seals, these were more preventative as these seals weren't leaking. I also changed out the throw out bearing (clutch, pressure plate and pilot bearing next).
Old Apr 10, 2016 | 10:13 AM
  #40
joey1320's Avatar
No need to explain any "unnecessary" repairs on a 25yo car - its just due for a full once over. Great work and awesome luck finding such a clean/rare piece of Honda heritage.
Old Apr 10, 2016 | 07:12 PM
  #41
PSU's Avatar
PSU
formerly DxHatchback
Thing is beautiful. Congrats man.
Also, nice work so far on the clean up.
Old Apr 11, 2016 | 08:16 AM
  #42
kp's Avatar
kp
Then the valve cover got some love. One of my favourite steps of the build.
Old Apr 12, 2016 | 05:26 AM
  #43
StreetLethaleg6's Avatar
great work.................give me the car now lol
Old Apr 12, 2016 | 08:01 AM
  #44
GodblessEMS's Avatar
This is pure awesome man. I'm glad this Si is in your hands. Subscribed.
Old Apr 12, 2016 | 08:54 AM
  #45
kp's Avatar
kp
New clutch and pressure plate installed and torqued. Transmission bolted back on as well.
Old Apr 14, 2016 | 07:09 AM
  #46
kp's Avatar
kp
The mess of oil inside the intake tract bothers me and I question the effectiveness of the PCV system. Far too much oil is making it's way back into the charge air.
Old Apr 14, 2016 | 10:58 PM
  #47
jonGSR's Avatar
Amazing work going on here.
Does your Si have a lot of miles on it?
Since the transmission is out, possibly change the input shaft bearing and seal? Always a good idea to replace since it's such a PITA to do so if the bearing starts acting up and making noise.
Old Apr 15, 2016 | 07:46 AM
  #48
kp's Avatar
kp
It's fairly low (about 192k kms, 119k in the old money). I left the trans alone throughout this rebuild, it's had a very easy life so I'm not overly concerned about it.
Old Apr 16, 2016 | 02:31 PM
  #49
kp's Avatar
kp
The engine is mostly assembled now, just a few details to sort out from here.
This is a comparison of a typical eBay kit gasket and the OEM D16Z6 Honda gasket
Thickness comparison of D16A6 and D16Z6 3 layer gasket
Old Apr 20, 2016 | 02:07 PM
  #50
kp's Avatar
kp
During disassembly I snapped a few of the studs on the cast manifold. I planned on just replacing the studs but I later stumbled upon a partout for a newer Civic and bought the manifold (oem). The "newer" ones are actual bent steel tubing, and not cast. They're also a 4-2-1 design instead of just 4-1. I had to weld on my older exhaust brace bracket as it appeared my new one had been repaired at some point.
The welds aren't too pretty but that's flux core for ya.
