***The Official JRSC Thread***
Old Feb 2, 2013 | 04:13 PM
  #16976
AcuraIntegraLS-T's Avatar
Default re: ***The Official JRSC Thread
Originally Posted by delsol1225
Anybody knows if I can use a 12.5 compression block on my Supercharged gsr ?
On pump gas I'd say its not the best idea, but on e85 or race gas it wouldn't be an issue, I've done it.
Old Feb 2, 2013 | 05:48 PM
  #16977
HeikDiesel's Avatar
Originally Posted by Black R
Anybody breaking 300whp with the jrsc on a bseries?
I know some people were getting close...
Post up dynos!
I could break 300 with very minimal work. My setup is simple simple
Old Feb 3, 2013 | 12:57 PM
  #16978
delsol1225's Avatar
Thanks
Old Feb 3, 2013 | 03:49 PM
  #16979
~sp33~'s Avatar
EFB055
That's REALLY neat. Nice work.
Old Feb 4, 2013 | 12:46 PM
  #16980
wunfstgsr's Avatar
Loved
Community Favorite
Post up dynos!
300 Hp is diffrent than 300 WHP!
To hit 300 WHP will take some work.
My last ITR motor/ JRSC setup made 285 HP @ 12 psi on a Dynapack dyno, on a mustang dyno it would be close to 245 WHP!
My new centrifugal supercharger setup is at 280 WHP @10 psi on a Mustang dyno with maxed out injectors at 7600 rpm so its about 300 + WHP. @12 psi.
Soon hopefully this month i will have a dyno graph comparison with my old JRSC setup that made 285 HP with 12 psi and My Pro charger setup @ 12 psi on the same motor and similar mods to compare the difference on the dyna pack dyno! should be fun! i predict about 340+ HP with the new Pro charger setup.
Old Feb 4, 2013 | 03:18 PM
  #16981
dcs2ooo's Avatar
Anybody got this on a bseries in an EF?
I mocked mine up last night and the clearances are TIGHT.
There's no room back there.
Yeah, the clearances are a bitch in the 4g chassis. I thought it required a lot of banging to get the ITR motor in there. WAY more for the blower clearance. I literally beat the hell out of the firewall with a ball peen hammer for what seemed like an hour. Gotta get to a point where you can slip a belt past the pulley. When spring rolls around, I'll try to get some shots of the clearance. The car is in storage for the winter, thankfully.
Pics:
Here it is on the dyno. 222 whp @ 5psi.
Autocrossing it.
Old Feb 4, 2013 | 08:37 PM
  #16982
HeikDiesel's Avatar
Post up dynos!
Mine put 282 down to the wheels on a supetflow dyno. I bet with cams and can gears I could break 300. Or a crv pulley. I have the fuel for it.
Old Feb 6, 2013 | 07:52 AM
  #16983
Black R's Avatar
25 Year Member
What are the specs on your build?
My goal is 300whp roots blown.
What cams would you use?
Keep in mind I don't want to sacrifice midrange for peak.
Old Feb 6, 2013 | 07:55 AM
  #16984
Black R's Avatar
25 Year Member
Pics:
http://www.youtube.com/embed/BQq5i_ofKho?rel=0
Autocrossing it.
http://www.youtube.com/embed/7nq5ENlCatM?rel=0
Thank you.
Mine is an autox car too:
Old Feb 6, 2013 | 07:58 AM
  #16985
Black R's Avatar
25 Year Member
Oh I know I could break 300whp with a centrifugal sc or turbo, but I need the down low grunt from a roots blower for autox.
Old Feb 6, 2013 | 08:10 AM
  #16986
EFSedan#6's Avatar
Alright, the noob in me has come out. I picked up a set of used injectors, 310cc from a member on here, and now I am confused as to making sure they work and fit in my fuel rail.
They have the numbers D1720BA on them. They seem to be Bosch style. The guy I bought them from they are RC Injectors.
I have a D15B7 with a JRSC. Not running yet, but piling up parts. Will these work? Or what should I go with?
Old Feb 6, 2013 | 09:35 AM
  #16987
EFSedan#6's Avatar
Also, what o-rings am I supposed to use??
Old Feb 6, 2013 | 06:20 PM
  #16988
HeikDiesel's Avatar
Stock b16
JRSC with LHT. Custom heat exchanger. 11.2 peak PSI
E-85
3" Intake/Exhaust
Neptune
1000cc Bosch Injectors
That's really it. Torque curve is flat. Like I said if I could keep the belt from slipping a CRV pulley would put me over 300
Old Feb 6, 2013 | 09:19 PM
  #16989
EFSedan#6's Avatar
No answers on the injector question? :-(
Old Feb 7, 2013 | 02:58 PM
  #16990
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It appears that they are Bosch topped RC Injectors. Measure the width of the top of the injector (fuel rail end). They look too big for a standard Honda/Acura fuel rail, so you might have to bore it out to make them work. The large size is only for K series.
Old Feb 7, 2013 | 04:00 PM
  #16991
Thmanx's Avatar
Sharing some JRSC H22 love.
Old Feb 7, 2013 | 04:58 PM
  #16992
MRGRIM's Avatar
R.I.P. Mark
nice work Thmanx
Old Feb 8, 2013 | 08:06 AM
  #16993
EFSedan#6's Avatar
Should I purchase an aftermarket fuel rail to avoid problems??
Old Feb 8, 2013 | 03:01 PM
  #16994
MRGRIM's Avatar
R.I.P. Mark
OEM or aftermarket rail isnt going to be any diffrent
you will just have to check if they fit
if they dont fit , make them fit or buy new injectors
Old Feb 8, 2013 | 03:28 PM
  #16995
EFSedan#6's Avatar
I see this thread.... https://honda-tech.com/forums/forced-induction-16/d16-edelbrock-fuel-rails-cheap-3123074/
States the rails are machined for Bosch injectors. I want Golden Eagle, anyone running them with Bosch injectors? I have been racking my brain in the FAQ's to keep from bugging you guys.
MRGRIM you have been alot of help, I appreciate it. I am delaying my JSRC install for a while until I have EVERYTHING sitting here. No half-assed ****....besides stock non-vtec. lol
Old Feb 8, 2013 | 04:09 PM
  #16996
MRGRIM's Avatar
R.I.P. Mark
ok lets start again
any fuel rail you get will fit
be it OEM or aftermarket
they will only fit the same fitting size as OEM injectors Ie:- the hole for the injector
if the ones you have are to big its either mod the rail
or
new injectors
Old Feb 9, 2013 | 01:59 AM
  #16997
wantboost's Avatar
Who is Mr Robot?
Yes, as these people habe stated... its only for a style of injector.... almost every injector is modeled on Bosch's general design.. so if these are bigger than OEM Honda units then no matter what rail you use, it will have to be modified.
Part number you have is D1720B-01D034B
The injectors are 315cc Lucas injectors.. 12ohms, ev1 style connector. Split fountain discharge
And THEY ARE NOT FOR A HONDA RAIL. I just looked it up..
This is the part number you need.. D1720B-01D034-325B
You can clearly see the difference in the rail side of the injector, its been cut down to fit our smaller rails.
So what you have won't won't unless you have your existing rail modified. No shelf b/d/h series rail will fit them.. or sell them and take it as lesson learned
Oh and to Thmanx, I've been looking for a good air tool for port work. What's the unit in the picture? Seems solid and easily controllable.. plus its looks small overall so it can go in tight spots
Old Feb 9, 2013 | 04:57 AM
  #16998
Black R's Avatar
25 Year Member
Just go with a bigger injector.
I have 550cc for my blower project and wish I had gone with 750cc because I'm going to do an e85 tune also. :/
Old Feb 9, 2013 | 01:21 PM
  #16999
Nevyn04's Avatar
So I decided today that I would do a slight porting of my JRSC and make a plate to block off my silencer ports... That didn't happen because I couldn't get the SC off.... Anyone know of a decent how to? Can't find any on removing a JRSC from b16. Spent a couple hours just frustrating myself.
Old Feb 9, 2013 | 02:53 PM
  #17000
MRGRIM's Avatar
R.I.P. Mark
try just dong the instructions backwards to get it off
