overheating civic
Old Jan 13, 2013 | 11:10 AM
bartleby13's Avatar
Default overheating civic
hi,
i have a 98 civic that has started to overheat. ive only had it a month and its been fine up until now. the temperature gauge rises to near maximum after about 10 minutes of normal driving (without being stuck in traffic or anything). turning the heating blowers on will drop the temperature back to its normal level within no more than 20 seconds. as soon as i turn the heating off again the temperature creeps back up. can anyone suggest what is causing this please? thanks in advance.
Old Jan 13, 2013 | 11:13 AM
grumblemarc's Avatar
The Grumpiest
Default Re: overheating civic
Stop driving the car immediately until you figure this out. Does the fan come on? Is the coolant actually circulating in the loop? Does the cooling fan actually work? Are both upper and lower radiator hoses hot?
Former User's Avatar
Never let the temp gauge reading rise above the halfway point. Otherwise, you risk destroying your engine.
Have you checked the coolant level in the reservoir and radiator? Is coolant being lost?
Have you tried replacing the thermostat?
Old Jan 13, 2013 | 11:24 AM
bartleby13's Avatar
thanks for speedy replies. i have checked the levels in the reservoir and radiator and they are normal. im not losing coolant. i have not tried replacing any parts yet as i preferred to seek advice first. i dont know whether the fan comes on yet but i was concerned that it would get so hot within only 10 minutes of driving. and thats driving at speed so under normal circumstances i shouldnt think the fan would have come on anyway? my main concern here is a head gasket obviously, does this sound like a possibility?
Old Jan 13, 2013 | 11:29 AM
The Grumpiest
Check everything else first. Don't jump to conclusions.
Old Jan 13, 2013 | 11:36 AM
Start with replacing the thermostat and bleeding the cooling system. Then go from there.
Checking whether the radiator fan comes on is always a good idea, but I think the problem lies elsewhere.
Old Jan 13, 2013 | 11:40 AM
bartleby13's Avatar
i just ran it for 5 minutes to see if both of the pipes on the radiator heated up. the top was quite nice and warm and the bottom was still stone cold. being none to knowledgeable i presume this would point towards a circulation issue? pump perhaps?
Old Jan 13, 2013 | 11:41 AM
The Grumpiest
Thermostat more than likely.
Old Jan 13, 2013 | 11:43 AM
bartleby13's Avatar
ok that is where i will start then. thank you very much for the help
It's rare for Civic water pumps to fail. When they do, they leak from the bleeder holes, typically.
Old Jan 13, 2013 | 11:45 AM
98civdx's Avatar
Master Detailer
Replace the thermostat and bleed the system.
Replace it with an OEM part.
Old Jan 13, 2013 | 12:03 PM
Root16's Avatar
You don't need to replace the radiator cap as well?
Old Jan 13, 2013 | 12:08 PM
The Grumpiest
Not really. At least, not at this point in time.
acidseven
May 16, 2019 10:26 PM
aws140
Aug 12, 2007 09:36 PM
spock_rocker
Jun 6, 2005 03:32 PM
LoooseGSR
Jul 15, 2003 10:49 PM
