gas gauge problem
how is it going guys, so i got a question???? i have a 94 dx coupe i did a eg cluster swap, and it worked fine the first time i hooked every thing up but now the gas gauge just gos all the way up and i know the tank is almost on the red line,
so my question is should i look for another cluster or is there any way to fix this my self
any help would be great thanks
I had the same problem back when I had my SIR cluster... so what cluster did you swap in? eg6 sir with white faces or black faces?
I tried looking for solutions too, and there was not too much I could do, the most likely cause is maybe a bad connections on the copper backing. They use very thin copper wire on the back of the fuel and temp gauge, often these wires can snap....
Unless someone else has some input, which would be appreciated
then you might have to buy a new cluster.
My other suggestion is to have some one take apart their cluster and just sell you the fuel/temp gauge unit, but if it is a white face sir cluster, that will be very rare to find.....
(I swapped mine with a stock usdm black face fuel/temp gauge, it was easy and worked, just didnt look nice, now I did a s2k cluster swap
hope this helps!
then you might have to buy a new cluster.My other suggestion is to have some one take apart their cluster and just sell you the fuel/temp gauge unit, but if it is a white face sir cluster, that will be very rare to find.....
)hope this helps!
thanks for all the help guys, i dont think its the float because when i put my old cluster in it works fine,but the cluster swap i did was a eg (92-95 si black faces) cluster in my 94 ej1, im going to try what you guys said and see what happens, but i was just thinking when i went to put the new cluster in i have a screw driver with a magnet on it and it might of touched the back of the fuel gauge (the part with the copper wire) could that have jack it up thanks everyone
The contacts on the back of the gas gauge are ultra-sensitive to over-tightening. They've been over-tightened by someone, breaking the connection to the cluster circuit board. Countless people have done this...it should be a FAQ. It is fixable with a soldering iron, but it's easier to just find another gas gauge from a donor cluster.
fm
fm
fm
fm
A multimeter, but I'm not sure where to touch the contacts off hand. I'd have to look. Deschlong has done this repair before, so you might want to PM him. I just replaced my gauge with a known working one and made sure to go easy on the screws.
fm
fm
It's f***ed. Get out your soldering iron, and put aside a few hours to dedicate to this. Pull apart the gauge and examine your copper wiring.... you'll see where it's broken. You'll also see why it's a very frustrating repair.... but do-able! You will need something conductive between the end of the copper wire and the contact. I used a very small piece of sheet metal.
And for God's sake, tell all your friends - when you're working on the fuel gauge:
DON'T OVER-TIGHTEN THE SCREWS
thanks for all the help got it fixed and if anyone has the same problem just send me a msg and i can help now that i know what to do
, DON'T OVER-TIGHTEN THE SCREWS because thats what caused the gauge to brake away from the copper wire, how i fixed it was i took a piece of extra wire i had and striped it down to were i could pull a thin piece of copper wire and then i just soldier a piece to the broken end of the wire and the other piece was soldier to the screw
thanks, its was a lot easier
than i thought and i would of never know what to look for because i am still learning when it comes to cars, thanks H-T for being here its a good way to learn and not get then run around, wish i would of found
H-T two years ago lol
drewbal, it would be nice to see pics of your repair so that we can add this to the FAQ sticky. An easy fix for this would be really nice to have there as this question comes up several times a year.
fm
fm
no problem, i have pics of a dx cluster but i am sure they all work the same and you do not want to over tighten the screw on any cluster lol
First you want to take off the screws to the gauge that has been broken due to over tightening.
second you need to remove the gauge and pull it out, now you can remove the metal case that is around the copper wire, you can see what it should look like in the next pic
now that you have it all apart you can take a look at it and if its broke you would see a crack or split in the plastic that the screws go into, if its cracked then more then likely the copper wire has broke off the metal from over tightening all you need to do is find the broken wire and reconnect it with a piece of extra wire you have around just strip the wire down were you can just have a single strand of copper wire next get out the soldier iron and soldier the two ends that have broke and your all done just put everything back together and your done
i dont have a pic of the repair but if you need any help or have any more questions im here to help and return the favor just send me a msg. or post , sorry it took so long to post this but i have been pretty sick trying to pass some kidney stones man there no joke
lol
lol
If you loved me, you'd all sell me your magic cards to me today
Hi sorry to message you about an old thread. But i was woundering if you would be able to help me out a bit.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/gas-gauge-problem-3018708/
someone got yelled at 3 YEARS AGO for bumping this OLD thread, and here you are, derping all over the ******* place, bumping it AGAIN. START YOUR OWN THREAD. they're free. there is plenty of room on the internet for it.
MTarry
11
Jan 15, 2013 06:46 PM
professorman
Jan 10, 2003 08:39 PM
jdmhondageek
Mar 19, 2002 07:57 PM
Nice! Glad you got it fixed. Good idea using a thin strand from inside another wire.
