Honda S2000 Honda S2000
DIY rear axle CV cup swap
Old Nov 4, 2009 | 06:24 PM
rice4life's Avatar
Default DIY rear axle CV cup swap
i was getting rear vibration during hard cornering while on throttle at the track last week. i did some research and found out that the rear CV was pitted, most commonly on the driver side. so swapping CV cup from passenger side to driver will provide a new surface and fix the problem, until it wears out again.
you can remove the whole axle from the hub but i don't think it's necessary but might make it easier if you want to completely clean out all the old grease.
here are some pics.
removing the lower control arm ball joint.
removing the boot clamp to be reused later.
CV cup is out.
you can see the lighter grease in the passenger cup and the darker grease from the driver cup on the paper.
you can see the pit in the CV cup. this was the worse one. the others weren't as bad.
Mobil synthetic extreme pressure grease.
all back together.
Old Nov 4, 2009 | 07:19 PM
frankdatank's Avatar
Default Re: DIY rear axle CV cup swap
i did this like 4 years ago. worked out for me too.
Old Nov 4, 2009 | 07:41 PM
Sex2k's Avatar
New User
I need to do this soon
Old Nov 4, 2009 | 08:38 PM
dagle's Avatar
nice pictures.
for those of you planning on doing this, wear a face mask. axle grease smells like death
Old Nov 5, 2009 | 03:59 AM
ReddotsS2K's Avatar
Can't see the pictures but a good write up. I had to do this a while back and it was a huge pain in the ***. If i has to do it again i qould prob remove the axles, because if not you pretty much need to remove the rear end
Old Nov 5, 2009 | 04:21 AM
rice4life's Avatar
not sure why you would have to pretty much remove the rear end. you can see from the pics that there are plenty of room to work. at first i though i might have to remove the exhaust to get the passenger side CV cup out but i was able to maneuver it around and get it out.
if you remove the lower control arm ball joint, then you can push the hub out far enough to pull the inner CV out from the rear diff. then you just remove the boot clamp and pull the cup out. it took less than 2 hours, could probably have done it in 1 hours if i was in a rush. i'm just saying that this is not as big of a job as some others make it out to be.
Old Nov 5, 2009 | 10:13 AM
White Smoke's Avatar
i my honda
Global Mod
Nice Writeup!
Old Sep 7, 2011 | 04:26 PM
usafstud's Avatar
sorry for resurrecting the dead, but do you need to redo the alignment when removing the lower control arm ball joint??
Old Sep 13, 2011 | 08:14 AM
apwhat's Avatar
no alignment needed, lower ball joint is the only thing removed/unbolted.
ug.. i also need to do this.. as well as make some solid rear diff mounts
Old Sep 14, 2011 | 08:45 AM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
can you explain why this happens? is it because u dont have axle spacers ? and your car is lowered?
Old Sep 16, 2011 | 10:39 AM
RED_90TEG's Avatar
anyone?
Old Sep 16, 2011 | 11:10 AM
gentek1145's Avatar
Nice
Old Sep 16, 2011 | 11:13 AM
RED_90TEG's Avatar
this is a useless thread if u dont explain why this happend... i think its because u dont have axle spacers ...
Old Sep 17, 2011 | 04:38 AM
rice4life's Avatar
it has nothing to do with axle spacers or not. axle cup just wear out from hard use. like if you have more power than stock or racing.
Old Sep 19, 2011 | 07:43 AM
RED_90TEG's Avatar
cool thx... more from hard launches ? or over all use..
Old Oct 4, 2011 | 01:00 AM
zwin's Avatar
can this be done by just unbolting the the top control arm? where do you get the ball joint remover?
jimmy o.
Dec 31, 2009 04:51 PM
EGII
Suspension & Brakes
May 27, 2008 01:06 PM
bab33face
Oct 22, 2006 01:45 PM
Touge Tuning
May 18, 2006 04:22 AM
drudy
Feb 1, 2005 09:09 AM
