Staging brake setup
Old Apr 22, 2006 | 02:45 PM
ranta18's Avatar
Default Staging brake setup
This is brand new, never used. Either cut the foot pad off or just take a tube and drill 2 holes in it to have a nice handle. The line from the master cylinder goes to the rear brakes. Much better than using a parking brake to launch.
$100 shipped
Old Apr 24, 2006 | 04:42 AM
ranta18's Avatar
Default Re: Staging brake setup (ranta18)
Old Apr 26, 2006 | 09:16 PM
ranta18's Avatar
bump
Old Apr 27, 2006 | 12:13 PM
ranta18's Avatar
bump for the drag guys needing this cheap
Old Apr 28, 2006 | 06:32 AM
ranta18's Avatar
I may just put this on my car... its a deal for someone though.
Old Apr 30, 2006 | 12:24 PM
ranta18's Avatar
up
Old May 3, 2006 | 09:22 AM
ranta18's Avatar
bump
Old May 3, 2006 | 11:18 AM
ReDemoN's Avatar
DixielandImports Please
Explain to me how this thing works.
Like where it goes and stuff.
Old May 3, 2006 | 12:46 PM
ranta18's Avatar
Default Re: Staging brake setup (ReDemoN)
Here is an example:
Mount it somewhere in the cabin where you can reach it. You "T" it in to the rear brake lines. When you pull it towards you it locks the rear brakes. Do the burnout, let go, line up, stage, pull it towards you again, bump in, let go when you want to launch, and reach for the shifter. Much easier and better than trying to use the e-brake.
Old May 3, 2006 | 01:49 PM
ReDemoN's Avatar
So this is good for preloading the clutch so to speak?
Old May 3, 2006 | 02:39 PM
ranta18's Avatar
Sort of. You hold the lever back and it locks the rear brakes which holds the car still. Pre-load the clutch so its ready to go. Then just let go of the lever, slip the clutch, give it gas. Much easier and nicer than having to mess with the ebrake. The ebrake you have to told up hard and when you let it go you have to make sure its down all the way. This you just pull back with little effort and then let go.
Old May 9, 2006 | 10:06 PM
ranta18's Avatar
Old May 15, 2006 | 02:30 PM
ranta18's Avatar
bump
Old Jun 16, 2006 | 09:56 AM
ranta18's Avatar
BUMP
Old Jun 20, 2006 | 08:09 AM
ranta18's Avatar
Fibercation
Sep 14, 2010 06:07 AM
RookieCivic
Aug 26, 2010 03:39 PM
hazard_one
Jun 18, 2006 12:30 PM
SLAMMED_EF8
Mar 25, 2006 03:03 PM
Airbag Club
Jan 28, 2005 06:38 PM
