your alignment specs??
memoryFAB.com representative
im most likely going to need an alignment after the brake conversion so i was wondering if i could have mine modified for a daily driver/ autox car??? i wont be running a camber kit or anything adjustable. any help would be great. thanxx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spock_rocker »</TD></TR><TR><TD CLASS="quote">im most likely going to need an alignment after the brake conversion so i was wondering if i could have mine modified for a daily driver/ autox car??? i wont be running a camber kit or anything adjustable. any help would be great. thanxx
If you don't have any camber adjusters then what are you asking? The only thing you could change is your toe settings.
1/4 inch total toe out front, 0 toe rear, if you don't mind a 'little' wear on the inside edge of your tire.
Some will say 1/4 inch toe out is too much, but I like it just fine.
Of course, this means you'll have to calculate back to degrees, and calculate PER SIDE, when you go to an alignment shop. I told a shop "xxx degrees total toe out in front" and they gave me twice that.
If you're going for 1/8th inch toe out, that's 1/16th per side, and about .15 degrees per side.
Some will say 1/4 inch toe out is too much, but I like it just fine.Of course, this means you'll have to calculate back to degrees, and calculate PER SIDE, when you go to an alignment shop. I told a shop "xxx degrees total toe out in front" and they gave me twice that.
