Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Window Net mounting....
Old Feb 4, 2003 | 07:26 AM
MattD@Stoptech's Avatar
Default Window Net mounting....
Could you guys help me out with this?
We are trying to figure out the best way to mount a window net in my car, the top mounting bar would be mounted to main hoop and the a-pillar leg, but I'm having troulbe figuring out what to mount the front lower bar to. The nascar bars are fairly low, so that the bottom of the net is noticably higher than the nascar bar, so if i wanted to run a tab from the nascar bar it would have to protrude fairly high up. How did you guys do it? Any pix?
Matt
Old Feb 4, 2003 | 07:28 AM
speedracer33's Avatar
Default Re: Window Net mounting.... (El Pollo Diablo v3.5)
I had a long post for the bottom of the net in the CRX, that fit into a holder on the A pillar bar...
Matt
Old Feb 4, 2003 | 07:30 AM
DR's Avatar
DR
Here is what I did
Old Feb 4, 2003 | 07:34 AM
Default Re: Window Net mounting.... (DR)
DR, any closer pix of that front bottom mount? Does it pivot down?
Old Feb 4, 2003 | 08:24 AM
AdamITR's Avatar
Here's mine:
Old Feb 4, 2003 | 08:30 AM
Honda318dx's Avatar
Default Re: Window Net mounting.... (AdamITR)
Here's mine:
My piper cage will be done tomorrow, woopie!!!!
Old Feb 4, 2003 | 08:44 AM
Thanks for the help guys,
Adam, does that bar pivot down, or is it permament?
Matt
Old Feb 4, 2003 | 08:48 AM
phat-S's Avatar
Maybe its the angle but I would have thought from your pic that our upper bars are roughly the same height.
(the front tab is hard to see but its against the front pad where they split)
Old Feb 4, 2003 | 09:02 AM
Geezer's Avatar
Here's a solution on a CRX:
And a closer view:
Edit: Damn, gotta wash the inside of that door.
[Modified by Geezer, 1:09 PM 2/4/2003]
Old Feb 4, 2003 | 09:09 AM
phat-S's Avatar
Default Re: Window Net mounting.... (Geezer)
this might be one of those, "I like mine cause ... its mine" but I don't like the idea of those metal bars and hinges being on the inside of the cage. How mine was done was by fashioning the forwardmost bracket to the top of the bar not the inside - just my view point of-course but seems a lot less likely to become a wrist/forearm breaker.
Old Feb 4, 2003 | 09:20 AM
AdamITR's Avatar
Default Re: Window Net mounting.... (phat-S)
Yes, the window net does swing down. Corey ... make sure to post some pics of your new cage .
Old Feb 4, 2003 | 09:25 AM
CRX Lee's Avatar
I've done a lot of CRX cages and several variations of the lower net bar. Some I liked, others I didn't. You guys have shown some nice examples. If you don't want the forward vertical bar to the rod, I've done it with nylon/cloth seat belt webbing and it gives a bit more "give" without being weaker.
Old Feb 4, 2003 | 09:51 AM
johng's Avatar
I have the same problem. I'm thinking about using thin steel cable (twine) and using eyelets on the ends. I'd wrap the cable around the door bar and crimp it together, then fasten the cable to the lower net rod ends with the eyelets. No welding or special brackets required.
Old Feb 4, 2003 | 10:47 AM
Geezer's Avatar
Should have done a picture with the door closed. At the point the front mount is attached, the whole bar is inside the door cavity. If the mount were on top of the bar, the net would catch on the door. Anyway, wait 'till you see how buried in padding it'll all be when I'm through with it.
Old Feb 4, 2003 | 11:39 AM
sackdz's Avatar
Chain with tie rod ends on either side of the bottom.
[Modified by sackdz, 3:41 PM 2/4/2003]
Old Feb 4, 2003 | 12:07 PM
phat-S's Avatar
Ahh gotcha - I hadn't thought of that. Yeah, I get wigged out with the little 1/2" tab that sticks up on mine but figured the net itself would keep me out of contact.
Old Feb 4, 2003 | 12:28 PM
johng's Avatar
Look at sackdz last picture. That's sorta what I'm thinking about (using less beefy hardware) for both ends. No bracket though. Just tie the cables to the door bar. It'll fall completely out of your way when not in use.
Old Feb 28, 2003 | 12:35 PM
johng's Avatar
Default Re: Window Net mounting.... (johng)
I brought this thread back instead of starting a new one. Who's got a GCR handy? What's the wording on the attachment hardware being all metal? Would a heavy gauge insulated speaker-type wire pass tech? I was at Home Depot and couldn't find the cable stuff I was looking for.
Old Feb 28, 2003 | 01:01 PM
bulldog_RS20's Avatar
I really like the way Adam got the latch out of the way with that extended top bar.
John, I heard some simular rumblings about metal fasteners. But Scroth has a new new out that uses webbing to attach to the bars...
http://www.lockracewrks.com/Products...%20racing.html
window net - half way down page.....
Old Feb 28, 2003 | 01:02 PM
Crack Monkey's Avatar
Don't have the GCR handy, but I believe all it says is metal hardware must be used (zip ties unacceptable). I don't recall much in the way of elaboration.
h22 civic
Apr 20, 2007 02:59 AM
weiRtech
Welding / Fabrication
Apr 2, 2007 10:21 AM
Black R
May 26, 2004 10:56 AM
10K2HVN
Jun 25, 2003 12:08 AM
