Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Wildwood Dpha vs ITR brakes
Old 03-08-2015, 06:47 PM
  #26
what gsr's Avatar
Default Re: Wildwood Dpha vs ITR brakes
Originally Posted by LightningTeg
Are you running the stock rubber hose? I love the way my Integra feels with HP+ and stainless lines. My old civic that I took to gingerman a few times had the same setup (DTC-60s) but stock lines and was noticeably 'squishier' but I didnt have a problem modulating.
stoptech lines. modulation is much better with dpha/dtc-60 then the gsr/dtc-60 setup.
Old 03-11-2015, 09:04 AM
  #27
yung98gsr's Avatar
I run my EK with ITR and Stoptech street pads on the track. Now that I use the brakes less they work for me fine. My car is too light and no ABS makes modulation upmost important. Changing pads was the biggest feeling difference in braking IMO.
Old 03-12-2015, 12:51 PM
  #28
widewhite's Avatar
any of you guys know if ITR calipers will mount right to my 94 rs stock set up
Old 03-17-2015, 11:04 AM
  #29
HondaRcB's Avatar
You'll need different rotors. ITR calipers and Mini Cooper rotors are pretty common. Believe my rotors for for a 2006 Mini non-S.
Old 04-04-2015, 07:30 AM
  #30
Honda Type R's Avatar
In regards to the locking up issues some of you had. Wouldn't a 15/16" MC have helped over the 1"?
Those of you with DPHA's, how's wheel fitment?
Old 04-09-2015, 09:23 AM
  #31
Jpres927's Avatar
They clear my 15x8 +35 Enkei PF01's just fine. I also have had a couple customers with 15x7+35 Enkei RPF1's and they clear with no spacer needed, the 15x7 +41 RPF1's will NOT clear this caliper.
Old 04-09-2015, 10:08 AM
  #32
miamirice's Avatar
I use the 949racing 15x8" wheel. I don't know the offset.
Old 04-09-2015, 10:46 AM
  #33
Jpres927's Avatar
I believe those are +36. You should be able to clear the DPHA caliper.
Old 04-10-2015, 10:12 AM
  #34
Miamirice, do you have anymore feedback on these brakes?
Old 04-11-2015, 05:30 AM
  #35
miamirice's Avatar
Actually.....I took the car for a pre-race shake down yesterday at PBIR. It has a long straight and is a track that's hard on brakes. Temperatures were very hot, the brakes were performing very nicely, at about 25min I noticed the car pulled a few times when I was hauling it down from 125ish to 50ish, however a few minutes later I had smoke so I came in and my NEW Axles had grease spatter everywhere. The grease was smoking on the hubs,rotors, calipers. So I am convinced my "pulling" was not the brakes but the grease on the brakes. I have 4 sprint races next weekend and will report on performance and pad life. At this point I prefer the engagement feel over the ITR but wonder how they will do with prolonged sessions when hot. I plan to cooling duct them after this next race weekend.
Old 04-11-2015, 06:29 PM
  #36
That blows about the grease. Did it get on the pads? I'm definitely looking forward to more feedback!
I've got a new axle on my car that has a torn boot and binds on hairpin turns. I need to replace it but I'm lazy lol
Old 04-12-2015, 07:22 PM
  #37
X2BOARD's Avatar
miamirice... what booster were you running on the ITR setup ?
I am about to put back my ITR setup, but the wilwood setup sounds attractive.
Why are people running the smaller mini rotor combo with the 17c calipers... are 11.1 rotor blanks hard to find ?
Old 04-12-2015, 07:51 PM
  #38
The Mini rotor has the right offset to be used with ITR calipers without needing to mill down the brackets. It also doesn't need to be redrilled since the Mini is 4x100. It's only 2mm smaller in diameter and 1mm thinner. If your brackets are already milled to use the Prelude rotor then it doesn't apply to you
Old 04-13-2015, 05:56 AM
  #39
miamirice's Avatar
I was running the 1" that is correct to the ITR calipers. While in theory you could use a 15/16 you certainly will loose pedal height and that's no good for heel / toe.
Old 04-13-2015, 04:10 PM
  #40
X2BOARD's Avatar
Oh, ok... I'm switching back from 4/114 to 5/114 and oem itr rotors. I see the value in the mini swap for 4/100 then... thanks Honda Type R.
miamirice, im going to use a 15/16 initially but hope to find an actual 1" booster, but with the dhcp, are you using the 1" booster still ?
Old 04-13-2015, 04:59 PM
  #41
miamirice's Avatar
Roger that. 1" MC. This require a diff booster than the 15/16 booster.
Old 04-15-2015, 07:25 AM
  #42
LightningTeg's Avatar
To update this, you can use 04-08 TSX brake pads and they will fit perfectly with no overhang with the mini cooper setup.
So ITR calipers, TSX pads, mini cooper 280mm rotors
Old 04-15-2015, 06:13 PM
  #43
Moderator
TheShodan's Avatar
ITR=NSX=TSX all run the same pad, with that ITR caliper.
Old 04-15-2015, 08:38 PM
  #44
I beg to differ. They are similar but not the same
https://honda-tech.com/suspension-brakes-54/itr-mini-front-brake-upgrade-look-here-update-3244097/
Old 04-16-2015, 11:08 AM
  #45
NipTucked's Avatar
Anybody know hawks part# for these calipers?? (wilwood)
Old 04-16-2015, 12:39 PM
  #46
Moderator
TheShodan's Avatar
https://honda-tech.com/suspension-br...pdate-3244097/
Just so that there wasn't any ambiguity here, please note that I didn't say anything about using the mini Rotors. I'm specifically looking at caliper/pad combination. Not taking a mini-rotor into account.
I currently have NSX calipers on my GS-R, have ITR calipers on my EM1, and OWN a 04-08 TSX. That combination is very interchangeable. Just perhaps not with a mini-rotor.
Old 04-17-2015, 05:22 AM
  #47
DixielandImports Please
ReDemoN's Avatar
I looked it up, seems Hawk do not make pads for this caliper
Old 04-17-2015, 05:46 AM
  #48
You said the TSX, NSX, and ITR all used the same pad. I was just showing you that the TSX does not use the same exact pad although it is very similar. I wasn't meaning in reference to the Mini rotor setup, just that they are different.
Old 04-17-2015, 06:22 AM
  #49
miamirice's Avatar
I have been using the Wilwood Polymatrix B. So far they are lasting but look to be hard on rotors.
Old 04-17-2015, 08:30 AM
  #50
At least rotors are cheap for the 10.3!
Quick Reply: Wildwood Dpha vs ITR brakes
