When to replace rotors?
Kinda of a stupid question ... but whats the best indication when it's time to replace the rotors? I'm getting a pretty distinct lip on the outside of the front rotors.
Got vibrations in the brake pedal when braking hard, like in autoX or exiting the freeway? Time to machine the rotors down if the metal is within spec.
For street stuff you can measure the rortors with a micrometer and check the specs in the shop manual if you have one.
For road racing I replace my rotors after 3 race weekends.
when they get smaller than they are allowed to get (see the manual for measurement)
or when they crack.. or have been hosed down with a fire extinguisher
or when your wheel falls off and it drags on the ground
or when a race official determines they are illegal.
When they look like this...
https://honda-tech.com/zerothread?id=181691
The lip is not that big of a deal with me... it only means that the pads have less rotor mass to use... and the cracking will get worse at a quicker rate
Will
[grammer]
[Modified by Willard, 1:43 PM 5/16/2002]
Will
[grammer]
I've only got superficial cracks and these rotors are still good to go. As a matter of fact they've never felt better. I could probably still track them (if I wasn't upgrading to larger rotors/calipers in a few weeks).
I admit that I was a little shocked when the folks at Wilwood told me that rotors that look like the last picture above are still OK...
Kirk
Kirk
But when the cracks go thru the disc... or collect pad material... then it is time to toss them.
Willis
mityVR6
Mar 26, 2003 08:22 PM
ryan12321
Feb 21, 2003 09:10 AM
