Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Wheel studs...extended
Old Apr 16, 2002 | 06:18 PM
TodaSi's Avatar
Default Wheel studs...extended
Anyone have a good place to buy extended wheel studs? With my 1" thick rotors I'm not getting enough threads on the studs to be comfortable. Would like to buy studs about 1/2" longer.
Any help?
Old Apr 16, 2002 | 08:05 PM
johng's Avatar
Default Re: Wheel studs...extended (TodaSi)
Something about using 1994 GSR rear studs since they're longer.....? There was a good topic a while back. Try the search.
Old Apr 16, 2002 | 08:06 PM
Chugger's Avatar
i got the arp studs from summit racing 11 bucks for a pack of 5 they are 2.5 inches long the skunks are 3inches long but of a lesser tensile strength?
id get the arp the part number is arp-100-7708
by the way how long are the stock studs
thanks
chris
Old Apr 16, 2002 | 08:15 PM
mojoGSR92's Avatar
Default Re: Wheel studs...extended (01VaS2K)
thanks
chris
Just curious if the part number is the same for a 90-93 Integra? Looks like the shop I took my car to (to get the chamfered rotor screws torched out) cross threaded a stud and just blew it on with the impact. I had a hell of a time getting the lug nut off.
While I'm doing the brakes and fixing the stud, I may as well upgrade in case I may need to use spacers in the future.
[Modified by mojoGSR92, 12:16 AM 4/17/2002]
Old Apr 16, 2002 | 09:58 PM
civicrr's Avatar
Stock studs (measured out of hub inside shoulder to end of threads) = 37mm
94/95 etc GSR stud = 47mm
You could also get the ARP studs. 2 1/2" = 63.5mm. Be advised that the knurl is a bigger diameter than stock. If I remember correctly, the stock knurl is around .483. If you go to the ARP, you will need to drill out the hubs to 1/2". There are people they say just force them in. Hmm, can you say stress riser? How about stress crack?
Old Apr 16, 2002 | 11:08 PM
DB2-R81's Avatar
25 Year Member
Default Re: Wheel studs...extended (civicrr)
Go to your local parts store and ask for a Dorman (manufacturer) 610-323 wheel stud. They are M12X1.5, are twice as long as the stock studs, have the same knurl size, and are about $1 a piece. Would you believe that these are actually over length replacement studs for many GM applications?
Or 86-89 Teg rears. 48 mm long vs. 39 mm for the stockers.
12mm X 1.5 Perfect for 1/4" spacer
[Modified by DB1-R81, 12:11 AM 4/17/2002]
Old Apr 17, 2002 | 07:17 AM
TodaSi's Avatar
Default Re: Wheel studs...extended (DB1-R81)
Thanks everyone for the replies.
Old Apr 17, 2002 | 10:23 AM
Austin's Avatar
Hey Chad...here is a link on extended wheel studs that was posted by jeff652 aka Jeff Sloan.
https://honda-tech.com/zerothread?id=122143
Austin
Old Apr 17, 2002 | 05:45 PM
Aahj's Avatar
Default Re: Wheel studs...extended (Austin)
I got my ARP extended wheel studs from http://www.summitracing.com
great customer service! great people to buy from! fast delivery!
good luck,
aj
Old Apr 17, 2002 | 05:48 PM
4doorH22's Avatar
Default Re: Wheel studs...extended (ajn)
AJ, did you drill out your hubs or force the ARPs in there?
Old Apr 17, 2002 | 06:03 PM
Aahj's Avatar
Default Re: Wheel studs...extended (4doorH22)
I don't know. I only had them installed on the rear. So, I took the hubs off of the trailing arms from the rear discs and took them to a machine shop to get the studs pressed in. They didn't tell me whether or not they had to drill out the hubs.
here is a pic:
sorry about the huge pics.
take care,
aj
Old Apr 17, 2002 | 06:12 PM
SEFIxCivic's Avatar
i'm not AJ, but i forced mine in awhile back and i havent had any problems, and I don't see any problems arising in the future. i think some people are over reacting. the hub is made of strong metal, and if it cracked that would be a real surprise. im actually glad that it's in there tight, if the stud starts spinning in the hub after the wheel has been tightened that's a very annoying problem.
Old Apr 17, 2002 | 06:49 PM
johng's Avatar
That's what I was trying to remember. Thanks
Old Apr 18, 2002 | 03:32 AM
Mista Bone's Avatar
D Tranny Guru
Works perfect for me! Just remember to have some open ended lug nuts if you need to run a spare/steelie on the front.
Old Apr 18, 2002 | 01:02 PM
Driven's Avatar
Default Re: Wheel studs...extended (Mista Bone)
i'm using Z-Speed wheel-studs.
Only had a problem with my old hubs (they spun).
HKSuperSi
Sep 13, 2007 11:05 PM
magoo_lc1
Aug 27, 2006 07:14 PM
GreenR
Sep 12, 2003 01:49 PM
pmachan
Mar 21, 2002 03:53 PM
olddriver
Jul 16, 2001 09:21 AM
