TRM wheels shakedown
You sure about that? I'm running a 15x8 +40 with a 225 R1R on a DC2. It wouldn't fit with the wheel moved over an inch further outboard without running a really wonky alignment.
Definitely share pics. I was one step away from ordering from their GA warehouse last night. Figured I'd better not put the cart b4 the horse considering I still have fabrication work and tuning to do!
-Drew
Hahaha I hear ya man, wheels are no good if your car still needs work..
Hopefully I got my order in on time, they said they had alot of pre orders for the 15x7.5. But werent sure how many sets they were getting in.
j/m with ya. look threw my build thead you can see the pictures of it front was running that offset with the rear 15x8 +36... But I have moved on to something bigger, 17x9 +20 on all 4. I will post up pics in my build thread but only the rear had to get rolled and pulled a bit to make it work other than that the fronts still are not touched
Nope not sure at all
got in my 15x7.5 +42 wheels with 205 kumho XS (was getting star specs, but they went on backorder while I was waiting on the wheels.)
TireRack was not to keen on sending me these in the first place.
They fit well, plenty of clearance up front. Came with aluminum hubcentric rings, i was expecting plastic so that was a nice surprise. My only concern is the rear upper control arm, it is REALLY close to the inner lip of the wheel, would guess 1/8th to 1/4 inch MAX of clearance. And its just the lip on the outer edge of the UCA. Should be ok? do I need to introduce the UCA to Mr. Grinder? It wont be a problem if I go with a rear camber kit. Circled in red is what im contemplating grinding off. When I upgrade to 225s im almost positive 6mm spacers/extended studs will be needed all the way around, and clearance shouldnt be an issue.
Because + 42s fit. The +20 require machining out the bore of the wheel which I was not comfy with. Most guys run 15x8 +36 on the 6ULs so they sit out 6mm or 1/4 inch further on each side compared to this setup. 12mm or less than .5 inch of total track width is IMO negligible. Assuming my calculations are correct.
I did... 7 20-minute sessions on my TR C1M's this weekend. They worked like they should.
I re-read and thought you said the Miata fitment, +30 are the ones you need to machine out. As for my decision to not do the +20, I just don't want to deal with an offset that low, and what issues may have come up, as far as bending sheet metal.
well as long as your happy.. all i had to do was role my rear fenders and remove my front fender liners and I am good.. I also like the +20 cause the seem to be more concave then the others..
these arrived yesterday :-)
Looking good! Glad to see alot more people are running these wheels now
Lets just hope they dont shoot up in price. Whole reason I went with these over the 6ULs is the fact if I bend one im only out $99 instead of $160.
EDIT: I just realized something, when you guys ordered your wheels were center caps included???? Cause I didnt get any
No biggie, my buddy ended up warping his on his TRM wheels for his M3 after his 2nd TT session after he got the wheels. But I think his brakes get a little hotter then the ones on my lil hatchback.
EDIT 2: Called and my center caps are OTW, should have been included with the wheels
Lets just hope they dont shoot up in price. Whole reason I went with these over the 6ULs is the fact if I bend one im only out $99 instead of $160.EDIT: I just realized something, when you guys ordered your wheels were center caps included???? Cause I didnt get any
His is picture of mine... 15x8 +20 with 205/50's
This is not my DD height I have a local car show this weekend so I dropped her down a bit
my normal height is about 1in higher that I DD with no issues all I have is my fenders rolled.
