Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
trailer tie downs?
Old Jun 22, 2006 | 05:45 PM
CBEengineering's Avatar
Default trailer tie downs?
how do you guys tie your honda/import cars down to trailers
i dont like tying to front suspension and then to back and pulling the other way...thats how weve been doing it on domestics for a long time...
but with $thousands of dollars in suspension and alignment it scares me....nor do i like tying to the body of the car because of suspension compression....my dad and bro-in-law lost a 55 chevy truck body like that....what about tire tie downs? and pics appreciated
Old Jun 22, 2006 | 05:54 PM
Crazydave's Avatar
Default Re: trailer tie downs? (CBEengineering)
The car does come stock with places to tie the vehicle down they are on the chassis itself.
Then some racers install their own tie down hooks for convenience and added towing safety.
Old Jun 22, 2006 | 05:56 PM
smokin rubber's Avatar
most tie down to the factory tow points. Jacking the car down keeps the suspension from moving, actually saving wear on the shocks.
What happened to the truck?
Old Jun 22, 2006 | 06:00 PM
Default Re: (smokin rubber)
truck... bucked around sub frame...hit bump suspension compresses...buck came undone and bridge wall saved truck..thats why i dont like to go around subframes or points on the sprung chassis even if suspension compression is minimal it can still happen....
Old Jun 22, 2006 | 06:15 PM
If you criss cross the straps, and use ones with clip in ends then there is never any slack.
I have only been towing for a couple years, but they have never come loose.
Old Jun 22, 2006 | 06:19 PM
johng's Avatar
Default Re: (CBEengineering)
The car has the ability to move more when anchoring to unsprung bits. I've been towing for a while with both a open and enclosed trailer and I've done it both ways. Using the factory front tow loops and the rear tow holes in the chassis (behind the doors) with "J" hooks is the best way, IMO.
$.02
Old Jun 22, 2006 | 06:20 PM
only lost one truck and all we needed was a couple parts from it...i still aint feeling pulling the body down... i dunno...maybe im just paranoid but it doesnt feel right and all our cars have 10k to 12k springs in the front and minimal suspension travel
Old Jun 22, 2006 | 06:50 PM
azian21485's Avatar
have never tied down a car but i remember redline covering this on speed channel with gforce
gforce basically said that you should allow the suspension to move if possible or **** will break. They basically wrapped theirs around the wheels.
just adding what i watched..no experience
Old Jun 22, 2006 | 06:56 PM
Default Re: trailer tie downs? (azian21485)
yeah thats basically what im looking for some wheel tie downs like around the tire
Old Jun 22, 2006 | 07:03 PM
tom91ita's Avatar
Banned
https://honda-tech.com/zerothread?id=1521704&page=4
note that "mr. koni" says to tie-down the car to minimize suspension damage.
Old Jun 22, 2006 | 08:52 PM
Crazydave's Avatar
Default Re: (tom91ita)
Your trailer should have springs that should take some of the road abuse, and keep your car from getting hammered on.
I wouldn't want my car loading and unloading itself on the trailer. To me it makes me think that the car would become a 2000lb bobble head, that was top heavy.
Old Jun 22, 2006 | 08:53 PM
Crazydave's Avatar
Default Re: (Crazydave)
I know the hard core NASCAR guys change their high dollar shocks to their crap shocks for transportation
Old Jun 23, 2006 | 09:09 AM
VenWood's Avatar
On the rear I use one strap on each side that goes through the rim and back to a tie down directlly in the floor each end has a 2 solid hoop which then connects to the floor with a D ring. The straps were excess material cut from the front ratchet straps available at Home Depot, heavy duty 3" yellow?. You hook up back then ratchet vehicle forward with the front straps hooked up to factory tow hooks.
Old Jun 23, 2006 | 02:20 PM
RedheadRacing's Avatar
Default Re: (VenWood)
I wrap the tiedowns around the tires. Also crisscross the tie downs and I have not had any problems. We are carrying 3 cars at a time and one is on a lift in an upper level of the trailer.
Shawn
Old Jun 23, 2006 | 04:55 PM
Default Re: (RedheadRacing)
thanks everyone i got some good ideas
dishjuarez
Mar 10, 2012 04:54 PM
hspoon
Jan 31, 2009 07:28 PM
jacob1217
Mar 26, 2007 12:51 PM
CBEengineering
Jun 24, 2006 08:05 PM
